> Subs in a GT4, thead turned to a how-to with pics
post Oct 5, 2009 - 10:09 PM
nammer
Joined Aug 22, '07
From Burnaby, British Columbia, Canada
I was wondering where I can run the positive wire through the firewall on the GT4. Drilling a hole in the firewall would be my last resort but if there is an easier solution then that would be great.
Please post pictures if you can so it's easier for me to see where to go through.
This post has been edited by nammer: Oct 29, 2009 - 5:02 PM
Replies (1 - 19)
post Oct 5, 2009 - 11:01 PM
Smiley
Joined Jul 28, '09
From Christchurch, New Zealand
When i did myne thre is a plastic bung on the battery side bout halfway down the fire wall with a arrow on it there was a slit under the arrow and i just made that biiger and went through there came out behid my glovebox no pics sorry hope that helps oh yea mynes a right hand drive vechile and battery is on left
post Oct 6, 2009 - 7:33 AM
look for the how to, i believe in the stickies it has pics
post Oct 6, 2009 - 10:29 AM
SoDo
Joined Dec 16, '07
From Chicago, IL
In my GT theres a port in the engine bay that goes to the wheel well. Put that throught that and then theres another port that comes into the car. If your gt4 has the same, you will have to take off your wheel and splash guard. Like the previous post theres a sticky or something that shows pic of what im talking about.
1999 Celica GT Hatchback
post Oct 6, 2009 - 2:01 PM
nammer
Joined Aug 22, '07
Thanks
I'll look through the stickies and will link it here in case someone else found my thread by searching
post Oct 6, 2009 - 8:27 PM
nammer
Joined Aug 22, '07
QUOTE (Smiley @ Oct 5, 2009 - 9:01 PM) *
I found that bung thing you speak of and it did have an arrow on it haha...It's getting kinda dark out so I will have to look into where it leads to tomorrow...
Will i need to take out the glove box to pull the wire through with more ease? I'll fiddle around tomorrow but if you have any other tips on take out the glove box then that'd be great
thanks in advance
post Oct 6, 2009 - 8:31 PM
yarik83
Joined Nov 22, '04
From FL
I wired mine through fender and under dash. Then from dash under carpets and rear seat to the trunk.
Captain Pessimist
post Oct 6, 2009 - 9:21 PM
nammer
Joined Aug 22, '07
QUOTE (yarik83 @ Oct 6, 2009 - 6:31 PM) *
I'll look into doing it that way too if it seems easier
This post has been edited by nammer: Oct 6, 2009 - 9:23 PM
post Oct 6, 2009 - 11:59 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
look where the loom goes through the firewall, passenger side, near the tower, pop a small hole in there and poke it through, it'l come out (if you poke it right) down at the passengers feet.
GRX133 Toyota Mark X 350s
post Oct 7, 2009 - 1:14 PM
Prometheus
Joined Apr 5, '09
From B.C. Coquitlam
yo! if u need any help bud let me know....
post Oct 7, 2009 - 2:14 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
So many BC members posting lately! What rock were they all hiding under? tongue.gif
Here are the pictures from my install:
(ignore that the wire after the fuse doesn't go into the fuse housing. That pic was from when I was running the wire.)
BEFORE:
AFTER:
Those pics are so old. I don't have that CAI or that battery anymore.
This post has been edited by Sinyk: Oct 7, 2009 - 2:17 PM
post Oct 12, 2009 - 11:22 AM
joehernandez
Joined Aug 5, '06
From San Luis AZ
well mine is not a gt four
but i will post pictures of how i did the wires.
pass them through the door.
i will post some pics later.
post Oct 29, 2009 - 4:24 PM
nammer
Joined Aug 22, '07
thanks a lot guys,
I took some pics of what i did as well and will upload it soon
ya we should all have a BC meet haha.. i know a few more people up for it too
post Oct 29, 2009 - 4:58 PM
nammer
Joined Aug 22, '07
So here are some of my pictures
Step 1: cut a slit into the rubber boot and feed the power wire though
Step 2: pull it out from under the glove box on the passenger side
Step 3: pop off the button that holds the panel below the glove box to tuck the wire behind it (purple wire is from amp to back of deck)
Step 4: pop off the door sill and tuck it as shown
Step 5: tuck it between the rear passenger seat and pull it through to the trunk
Step 6: wire up the amp and put the power wire into the "battery" slot. Blue wire goes from amp to sub, purple goes from amp to back to deck, thin purple is the remote wire also going to back of deck, and the red wire is the ground.
Step 7: ground the ground wire to the frame of the trunk (red ground in previous picture was too short so i joined it with a brown wire of the same gauge, should change it soon)
Step 8: tidy up the power wire in the engine bay, ADD a fuse, connect it up, test it out, and put the panels back together
post Oct 30, 2009 - 10:09 AM
Remanight
Joined Oct 20, '09
From NSW
nicely done, this is exactly how i did it aswell
DOSSSSSSSSSSS!!!!
post Oct 30, 2009 - 11:29 AM
Random_Stranger
Joined Mar 20, '07
From Bakersfield, CA
QUOTE (Remanight @ Oct 30, 2009 - 8:09 AM) *
post Oct 30, 2009 - 2:23 PM
Smiley
Joined Jul 28, '09
i did the same way also except put my amp under the passenger seat to save on boot space
post Oct 30, 2009 - 11:26 PM
nammer
Joined Aug 22, '07
QUOTE (Smiley @ Oct 30, 2009 - 12:23 PM) *
hmm that's a good idea..under the rear passenger right?...I'll see if i have time this weekend to look into doing that
post Oct 30, 2009 - 11:32 PM
black13
Joined Oct 11, '06
From calgary
For the amp install, did you run new wires from each speaker to the amp or did you tap in to the ones at back of the deck?
post Nov 2, 2009 - 7:11 PM
Smiley
Joined Jul 28, '09
QUOTE (nammer @ Oct 30, 2009 - 11:26 PM) *
um under the front passenger fits nicely and seat just slides over it when ppl jump in the back
Lo-Fi Version Time is now: December 2nd, 2024 - 8:28 AM
