Reverse light problem- automatic transmission |
Oct 12, 2009 - 10:38 PM |
Enthusiast Joined Oct 1, '09 From Arlington, TX Currently Offline Reputation: 0 (0%) |
I'm having a problem with my reverse lights in my 94 auto gt. Brake and tail lights work fine, but the reverse lights only go if I push the gear selector forward and to the right while in R. I searched around on here and found a few threads suggesting the back up switch on the transmission. Is this switch the same on an automatic? Is there any sort of switch on the gear selector? Trying to get this car inspected this week!
-------------------- Celica Timeline:
1994 Black Celica GT Coupe- CURRENT 1977 Silver Celica ST Coupe 1987 Red Celica GT Hatch 1987 Blue Celica GT Coupe |
Oct 12, 2009 - 10:54 PM |
d'oh. fixed my own problem. unplugged the harness and plugged it back in and it works great now!
Oct 12, 2009 - 11:42 PM |
Enthusiast Joined Jun 9, '09 From Saint Louis Currently Offline Reputation: 0 (0%) |
The reverse light switch on the automatic is the "park/neutral position switch" and it is adjustable. It sounds like it's out of place or the wiring harness is loose. Easy fix!
Nov 29, 2018 - 12:11 PM |
Enthusiast Joined Nov 29, '18 From Penarth, Wales Currently Offline Reputation: 0 (0%) |
Hi, sorry to bring this thread back, but where did you unplug and replug the harness? Sorry if it's obvious!
Dave |
Dec 5, 2018 - 5:12 PM |
Enthusiast Joined Dec 2, '18 From Cyprus Currently Offline Reputation: 0 (0%) |
Hi, sorry to bring this thread back, but where did you unplug and replug the harness? Sorry if it's obvious! Dave The neutral switch (https://contentinfo.autozone.com/znetcs/product-info/en/US/wl2/JA448/image/2/) is in front of the engine. If you also have a lag when dropping from D gear to 2nd you will need to remove the neutral switch and clean the dry grease and add fresh one. You can find a youtube video on how to do it (https://m.youtube.com/watch?v=XCvwj8u602I). If its just the lights it either needs adjustment (needle on N.S.) or its a wire issue. Hope you sort it out. |
Lo-Fi Version | Time is now: November 24th, 2024 - 2:49 AM |
