> Axles help!
post Nov 5, 2009 - 8:32 PM
fran
Joined Apr 28, '07
From Venezuela
Hi friends! i have a little problem with my axles!... Well the thing its when i bougth the swap the came with the gearbox! but when i remove the axles from de new engine i see that they are totally diferent from my old ones!... Anyones knows from what gearbox, car, etc are this axles??? if i buy a new pair they will fit into my celi? frown.gif frown.gif frown.gif
(The left one its from the old 3sfe engine, the cut one its the new axle laugh.gif )
Replies (1 - 16)
post Nov 5, 2009 - 9:51 PM
will your old inner joint go into the other axles cup? if it fits correctly then there ya go, custom axles! otherwise you need to tell us what trans you bought or what 'swap' you bought.
post Nov 6, 2009 - 5:11 AM
fran
Joined Apr 28, '07
From Venezuela
im shure that the cup dont fit because the other one is much bigger. i bought a 4gen 3sgte with fwd transmission but they dont specify the type :S
post Nov 25, 2009 - 5:26 PM
fran
Joined Apr 28, '07
From Venezuela
Ok, ill search around the web and i think that the gearbox that comes with the swap its an C52 gearbox. The axles cup are totally direfents, there are bigger!.. I will like to put a nice axles setup, like oem toyota axles that fits there nicely, any ideas? kindasad.gif
The othe solution its to chage to my old gearbox! but im shure she cant old the power kindasad.gif
There is a pic from a gearbox like mine
Thx
post Nov 25, 2009 - 5:58 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
wait........the c52 is from an A series toyota engine, why is it in a GT???
post Nov 25, 2009 - 9:12 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
Front axles:
PN# 43410 is your passanger side
PN# 43420 is your driver side
This post has been edited by Mstoochn: Nov 25, 2009 - 9:12 PM
post Nov 26, 2009 - 6:32 PM
fran
Joined Apr 28, '07
From Venezuela
nice info Mstoochn biggrin.gif... Ya its a A series, i moified the rear gearbox mount to do the fit in the celi biggrin.gif the engine & gearbox bolt up nice into the mounts. Now my big question is, the long of this axles will fit in the celica? they will fit in the outside peace ? kindasad.gif
post Nov 26, 2009 - 9:04 PM
Mstoochn
Joined Apr 27, '09
they are St215 caldina axles, which have the same wheel base depth. they are the only axle i no of that you can use with a c52 trans in a celica
post Dec 6, 2009 - 3:40 PM
fran
Joined Apr 28, '07
From Venezuela
so i must order St215 axles kindasad.gif ... Any ideas where i can buy those axles? kindasad.gif
post Dec 6, 2009 - 4:23 PM
Mstoochn
Joined Apr 27, '09
QUOTE (fran @ Dec 6, 2009 - 3:40 PM) *
yes, the FWD axles are available in northamerica, although not THAT easy to find. I belive there is also an alternative using a mix of inner and outers from the mr2 and st202 inners. I will look into it for you.
This post has been edited by Mstoochn: Dec 6, 2009 - 4:24 PM
post Dec 7, 2009 - 5:10 AM
fran
Joined Apr 28, '07
From Venezuela
iŽll find around the web too. I think that the st202 dont work because the other axle its bigger and i need the rear mount for the passenger side axle kindasad.gif. I saw some pictures in the web of an engine with the fwd trans, here its the pic so can have an idea:
Other thing its that im not pretty shure that my trans its a c52, but i read in some other forums that the c52 trans have a black cover (5th gear cover). Any other toyota trans with this black cover? :S.
Thanks a lot for your help Mstoochn!
post Dec 7, 2009 - 8:02 PM
Mstoochn
Joined Apr 27, '09
QUOTE (fran @ Dec 7, 2009 - 6:10 AM) *
locate the starter, look adjcent to the start and there will be a Serial Num for the tranny. 8E4 or 8E5 will be the first three digits of a C52 trans.
if this came from a st215 calinda is would have to be a c52
post Dec 8, 2009 - 5:11 PM
fran
Joined Apr 28, '07
From Venezuela
i dont see any serial number around there frown.gif .
post Dec 8, 2009 - 6:27 PM
Mstoochn
Joined Apr 27, '09
QUOTE (fran @ Dec 8, 2009 - 5:11 PM) *
hmmm.. perhaps i have the wrong information, i asure you the color is a light green tongue.gif
post Dec 9, 2009 - 5:34 AM
fran
Joined Apr 28, '07
From Venezuela
You are correct! its ligth green! laugh.gif ... here its the numers on the stickers
2410074140
228000-0833
A9(green) 06B2 (not painted, very hard to see)
post Dec 11, 2009 - 6:04 PM
fran
Joined Apr 28, '07
From Venezuela
any idea where i can get that stuff? .... the two axles and the middle mount smile.gif biggrin.gif
post Dec 11, 2009 - 7:33 PM
Mstoochn
Joined Apr 27, '09
yea thats from a fwd calinda... wow
u may need to go custom axles. or use the calinda half shafts with st185 or st204 axles with an axle spacer
Lo-Fi Version Time is now: December 2nd, 2024 - 11:06 AM
