FS: Audiobahn A4002V amp, Christmas deal!! $45 + Shipping.. retail price $120 |
Nov 7, 2009 - 11:31 AM |
Enthusiast Joined Jan 10, '09 From Burtonsville, Maryland Currently Offline Reputation: 1 (100%) |
Hey guys its your favorite seller again
I have now an Audiobahn A4002V amp thats good for up 800 watts. * RMS Power Output: o 100 watts x 2 chan. @ 4 ohms o 200 watts x 2 chan. @ 2 ohms o 400 watts x 1 chan. @ 4 ohms Bridged * Max Power Output: 800 watts @ 2 ohms * Class A/B MOSFET Circuitry * PWM MOSFET Power Supply * Non-regulated Power Supply * Semi-double Sided Glass Epoxy Circuit Board * 4-way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset * Air Induction Cooling Fan * Soft Start Circuitry * Cobalt Blue Illumination * Speaker level (high-level) inputs * Preamp outputs * Nickel-Plated Block Terminals * Bass Boost Control: On/Off (0 or +18dB) * Variable Low-Pass Crossover: 50-120Hz * Variable High-Pass Crossover: 50-750Hz * Signal-to-Noise Ratio: 100dB * Frequency Response: 10Hz-40kHz * Variable Subsonic Filter: 20-50Hz * THD: 0.02% * Input Sensitivity: 200mV-8V * Dimensions: 8-3/8"L x 11-1/16"W x 2-1/8"H Reason im selling this is because I made an error thinking I had to replace my old one.. turned out that it was just my RCA's that were bad.. so yea I have this one just sitting around when im sure someone else could use it. This thing can make basically any subwoofer thump real good.. ive been using 2 12 inch Dual subs.. not the best subs by any means but it sounds great because of the audiobahn amp I have. So yea $90 bucks + shipping for this.. I paid $130 for it. Thanks for looking This post has been edited by SlvrCelica09: Dec 19, 2009 - 1:22 PM -------------------- THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma.. 6gc.net's outlaw vigilante because im a LEADER not a follower. |
Nov 9, 2009 - 11:16 AM |
bumpy
Nov 9, 2009 - 10:15 PM |
Enthusiast Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) |
Time out:
Why is your sig so ridiculous and retarded? "6gc.net's outlaw vigilante because im a LEADER not a follower." LMFAO -------------------- |
Nov 10, 2009 - 12:15 PM |
Time out: Why is your sig so ridiculous and retarded? "6gc.net's outlaw vigilante because im a LEADER not a follower." LMFAO dont you have anything better to do rather than search for my C**K? geeze dude Im not worried about you.. why not return the favor? -------------------- THIS IS WHERE WE HOLD THEM!
Nov 11, 2009 - 10:08 AM |
bumpy
Nov 12, 2009 - 8:19 PM |
bumppp
Nov 14, 2009 - 7:06 PM |
bumpy
Nov 16, 2009 - 11:23 AM |
bumpp
Nov 16, 2009 - 2:04 PM |
Enthusiast Joined May 3, '09 From jacksonville/flemming island florida Currently Offline Reputation: 1 (100%) |
is it 800w max or 800rms?
i may be interested depending on how much my alighnment will be -------------------- 94 stx coupe, super mario kart beater
87 toyota 2wd truck, rebuilding engine 85 celica gt-s project |
Nov 16, 2009 - 4:00 PM |
is it 800w max or 800rms? i may be interested depending on how much my alighnment will be hey Joe, yes its 800w max.. I put more specs on the amp also on the main post. -------------------- THIS IS WHERE WE HOLD THEM!
Nov 17, 2009 - 2:45 PM |
bump
Nov 19, 2009 - 11:07 AM |
bumpy
Nov 21, 2009 - 12:26 AM |
bumpz
Nov 21, 2009 - 8:44 AM |
Enthusiast Joined Sep 6, '08 From Burlington Currently Offline Reputation: 0 (0%) |
Is the amp a class a/b or is it a d-class?
Nov 21, 2009 - 4:05 PM |
Is the amp a class a/b or is it a d-class? its class a/b, i put that spec and others on the main post.. Ill repost it here tho for you guys * RMS Power Output: o 100 watts x 2 chan. @ 4 ohms o 200 watts x 2 chan. @ 2 ohms o 400 watts x 1 chan. @ 4 ohms Bridged * Max Power Output: 800 watts @ 2 ohms * Class A/B MOSFET Circuitry * PWM MOSFET Power Supply * Non-regulated Power Supply * Semi-double Sided Glass Epoxy Circuit Board * 4-way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset * Air Induction Cooling Fan * Soft Start Circuitry * Cobalt Blue Illumination * Speaker level (high-level) inputs * Preamp outputs * Nickel-Plated Block Terminals * Bass Boost Control: On/Off (0 or +18dB) * Variable Low-Pass Crossover: 50-120Hz * Variable High-Pass Crossover: 50-750Hz * Signal-to-Noise Ratio: 100dB * Frequency Response: 10Hz-40kHz * Variable Subsonic Filter: 20-50Hz * THD: 0.02% * Input Sensitivity: 200mV-8V * Dimensions: 8-3/8"L x 11-1/16"W x 2-1/8"H -------------------- THIS IS WHERE WE HOLD THEM!
Nov 23, 2009 - 11:40 PM |
bumpy
Nov 26, 2009 - 2:31 PM |
sounds like bump 2 meeeeee
Nov 29, 2009 - 11:33 AM |
bumpz
Dec 1, 2009 - 6:16 PM |
bumpz
Dec 1, 2009 - 9:50 PM |
Enthusiast Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
Might be interested in this...I call dibs.
-------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Lo-Fi Version | Time is now: November 23rd, 2024 - 10:30 AM |
