engine swap |
engine swap |
Dec 15, 2009 - 2:50 PM |
Enthusiast Joined Nov 8, '09 From Tampa, FL Currently Offline Reputation: 0 (0%) |
when swapping the engine in an ST does the tranny have to come out too?
my problem: I'm trying to preplace my st engine and EVERYTHING is detached but the block is got coming apart from the tranny all the way. there's gap all around the block n tranny to the point where i can see the flywheel but that's where it stops. n that's where i am stuck. |
Dec 15, 2009 - 3:50 PM |
Enthusiast Joined Sep 27, '09 From Columbus, Ohio Currently Offline Reputation: 3 (100%) |
Dec 16, 2009 - 10:49 AM |
Enthusiast Joined Jun 20, '06 From Savannah, GA Currently Offline Reputation: 0 (0%) |
when swapping the engine in an ST does the tranny have to come out too? my problem: I'm trying to preplace my st engine and EVERYTHING is detached but the block is got coming apart from the tranny all the way. there's gap all around the block n tranny to the point where i can see the flywheel but that's where it stops. n that's where i am stuck. Do you have an auto or manual? If you have an automatic trans there are bolts holding the flexplate to the torque converter that have to be removed. You can do this by rotating the crank and viewing the bolts and removing them from the dust cover located where the oil pan and the tranny meet. If you have a manual transmission you may be getting hung up on the input shaft or one of the dow pins in the tranny. Feel free to pm me or post if you have any other questions. |
Dec 16, 2009 - 5:23 PM |
i have a manual and u were right. it was stuck on the input shaft.... now i'm having the reverse problem. i can't get the new block connected flush w' the tranny. the input shaft seems to be getting caught w' the clutch but on the wrong angle but for 3 hours of different angles there has been no progress
Lo-Fi Version | Time is now: January 5th, 2025 - 11:29 PM |
