Enthusiast ![]() Joined Jul 8, '09 From DuBois PA Currently Offline Reputation: 8 (100%) ![]() |
i did some diggin on the gb, and i notice there was more then one, but i also found this kit is more of a straight up kit instead of an angle up
so my question is, with the gb hinges work with a shaved handles kit? and if in fact they will work, what weight lvl popper should i get? thanks |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 22, '03 From NOVA Currently Offline Reputation: 16 (100%) ![]() |
hinges have nothing to do with poppers really. The door will pop out an inch or two and then you have to lift.
and there are no more GBs on hinges anymore. This post has been edited by playr158: Dec 30, 2009 - 1:27 PM |
yeah but when the door pops out with force against a hinge that only wants to go up, wouldnt that put stress on the bolts?
and the hinges are from the gbs |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) ![]() |
whats gonna make it pop out?
the poppers that are used when we shave your door handles
yeah but when the door pops out with force against a hinge that only wants to go up, wouldnt that put stress on the bolts? and the hinges are from the gbs the hinges do not just go up. The hinges open the door normally approximately ~6 inches (at the outter edge) and then it goes up. So no there is no additional stress. |
ok thanks
i was worried about the poppers when they said that the hinges from the gb where more of a straight up lift then an angle lift |
Lo-Fi Version | Time is now: February 20th, 2025 - 3:38 AM |
