> Is the E153 Invincible? No. Proof inside!, 445fwhp later..
post Jan 16, 2010 - 12:53 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
E153 LSD out of a 95' Mr2
My project 5s-gte (445whp) ran strong for almost 2000 km before i started getting a grinding in first gear... then i decided to shut some silly old man in his porsche 911 turbo up, happy to say he was no challenge.... downshifting back into first then rolling off on the next light... Well first became neutral....
And here's why:
Also managed to crack the casing... not sure which caused which tongue.gif lack of fluid destroyed the gear OR the gear caused the leak and fried the trans completely.
New project: E154F trans and caldina rear diff ..... i guess frown.gif
This post has been edited by Mstoochn: Jan 16, 2010 - 12:56 AM
Replies (1 - 7)
post Jan 16, 2010 - 1:05 AM
domyz
Joined Jul 29, '07
From Quebec, Canada
Gen 3 E153 got weak synchros on 1st and 4th, Gen 2 E153 got weak synchros on 2nd and 5th
This problem can lead to wear on gears.
My Gen3 E153LSD didn't work well with synthetic tranny oil, it grinded in 4th and the 1st was hard to get in
So I changed it with pennzoil synchromesh and it is like a new tranny.
Try that in your new tranny setup, this lighter oil is like magic and offer a good protection on bearings as well: change it every year because it's dino oil and not synthetic...
You can also try to add a small cooler instead of the small recirculation hose in the base of the gearbox, which also help bearings a lot.
post Jan 16, 2010 - 1:09 AM
Mstoochn
Joined Apr 27, '09
QUOTE (domyz @ Jan 16, 2010 - 1:05 AM) *
beh... i have been using penzoil synchromesh as alot of MR2OC kids suggest it.
post Jan 16, 2010 - 5:07 PM
domyz
Joined Jul 29, '07
From Quebec, Canada
It is very rare that I hear a E153 break on the gear and not synchros or bearings. If your synchros were good, this is abuse or front jumping or bad shifting. A gear like that can surely hold 800-900hp if you put power to it when it is fully engaged. E153 needs slow shifting IMO
This post has been edited by domyz: Jan 16, 2010 - 6:57 PM
post Jan 16, 2010 - 9:06 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
If that's what happened to your tranny after "shutting some old man in a porche up" it sounds like he's getting the last laugh.
post Jan 17, 2010 - 9:42 AM
D-Man
Joined Jan 18, '08
From Houston
QUOTE (Mstoochn @ Jan 15, 2010 - 11:53 PM) *
Just sayin...
This post has been edited by D-Man: Jan 17, 2010 - 9:43 AM
Damn D-Man - most impressive.
post Jan 17, 2010 - 11:11 AM
You downshifted into first...?
post Jan 17, 2010 - 2:04 PM
Mstoochn
Joined Apr 27, '09
QUOTE (Supersprynt @ Jan 17, 2010 - 12:11 PM) *
...light turnes red, u brake and down shift into second, then come to a stop and put it in first.... then u begin to release clutch and go again(ligbht turns green).... u give it gas and release the clutch and ur still sitting there, throw it in second and ur off, at s lightly slower pace, u'd think people here would have more than a blane idea of what im talking about.... your just fishing cuz you have nothing better to do lol
it was the take off that destroyed it, Notice the missing teeth! may have cracked and lost fluid prior to this from heat, really have no idea no puddle in my driveway kindasad.gif
BTW, if you have an older E153 looking for lsd, its up for grabs, going on FS soon.
This post has been edited by Mstoochn: Jan 17, 2010 - 2:15 PM
Lo-Fi Version Time is now: November 26th, 2024 - 10:47 AM
