> ground control install i made a bubu.
post Mar 3, 2010 - 2:07 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
on the rear installing ground controls did you guys have conned top hats?
i installed mine and in the front slammed its on the wheels but on the rear its still got good inch and a half gap??
theirs a rubber piece with a coupler is the spring supposed too slide around that?? or is the cone supposed to go inside it??
"she can polish my strut bar anytime As long as her blow-off valve's in good order"
Replies (1 - 10)
post Mar 3, 2010 - 2:13 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
The coned top hat is supposed to sit on top of the coil, with grease in between.
What is this rubber piece?
Post up a picture and I'll tell you what goes where.
**** Photobucket
post Mar 3, 2010 - 2:21 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
QUOTE (95CelicaST @ Mar 4, 2010 - 10:13 AM) *
on top of the rear theirs a rubber piece held on by a metal coupler was i supposed to take off the metal coupler(instead of tearing off the rubber of it?) than put the coilover around were the metal coupler was?
This post has been edited by terbear4god4life: Mar 3, 2010 - 2:22 PM
post Mar 3, 2010 - 2:32 PM
95CelicaST
Joined Feb 5, '05
No clue - mine didn't have any of that for the rear. Mine was the coned top hat sitting on the spring. Do you have the threaded sleeves set properly? Sounds like the front is way too low.
Take a picture of this rubber and metal coupler. The only rubber on my setup was a small O-ring that slid onto the shock body to hold the threaded sleeve in place.
**** Photobucket
post Mar 3, 2010 - 2:44 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Just like the bottom picture, cept you need the mounts on top of it. That should be it, only reason my mounts aren't on, cause I havn't taken them off the car.
post Mar 3, 2010 - 11:57 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
ill try too find a pic too post..im referencing off an02's celi too see were they should sit atleast..
post Mar 4, 2010 - 2:56 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
on the stock rear strut did you guys remove a dust cover from the top that had a metal coupler holding it up?
on the very top of the rear strut
post Mar 4, 2010 - 3:21 PM
rave2n
Joined May 29, '09
Yes.
post Mar 4, 2010 - 7:28 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
alright im done.
i took off the dust cover and grinded off the ring now it all sits great!
This post has been edited by terbear4god4life: Mar 4, 2010 - 7:29 PM
post Mar 5, 2010 - 11:59 AM
boosted185
Joined Aug 27, '07
From Summerville, SC
QUOTE (terbear4god4life @ Mar 4, 2010 - 7:28 PM) *
alright im done.
Hey dude, post pics! I wanna see how your car sits on those coilovers!!
www.tweakdperformance.com
contact@tweakdperformance.com
post Mar 5, 2010 - 3:33 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
QUOTE (boosted185 @ Mar 6, 2010 - 6:59 AM) *
alright im done.
alright ill go snap some right now
Lo-Fi Version Time is now: November 27th, 2024 - 2:49 AM
