> Johnnehh needs HALP, >.<
post Apr 5, 2010 - 10:37 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
Heyyy. I got new tires mounted and got everything balanced on the new Rotas, and when I was washing the car today and wiring up the fogs, I noticed something...
The front wheel on the driver side sits flush with the fender, and the front wheel on the passenger side is a little "sucked in".
I would say there is about an inch difference.
1996 Toyota Celica GT (GT4 conversion) - SOLD :(
2002 Audi A4 1.8T Quattro - Daily Driver
Replies (1 - 18)
post Apr 5, 2010 - 11:16 PM
whatthe
Joined Aug 13, '08
From Australia
First things first make sure the wheels are the same offset and that they didnt give you a wrong offset one.
post Apr 6, 2010 - 12:15 AM
ajmorris1977
Joined Jul 13, '09
i had that problem once and it turned out to be a bent lower control arm, $300 later it was fixed.....
You're here for a good time, not a long time. - Colin McRae
When in doubt... Flat out! - Colin McRae
Understeer is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you....
post Apr 6, 2010 - 3:59 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
your toe could be off a little. you got camber bolts on?
is the car pulling/drifting in one direction??
post Apr 6, 2010 - 5:02 AM
whatthe
Joined Aug 13, '08
From Australia
Firstly why is there a baby?
post Apr 6, 2010 - 9:26 AM
Keiri
Joined Mar 6, '04
From Charlotte, NC
QUOTE (whatthe @ Apr 6, 2010 - 6:02 AM) *
Seconded.
Has no more Celicas
post Apr 6, 2010 - 10:14 AM
CAMAricer
Joined Jul 25, '07
From San Francisco
Fact: Babes in any pictures adds +2 to coolness.
QUOTE (Keiri @ Apr 6, 2010 - 7:26 AM) *
Seconded.
2002 SC430 (WC) - 19" SSR Comp-H, Daizen swaybars, Sparco Demons, JDM Soarer conversion, carbon fiber spoiler, Injen intake, front strut bar, drilled/slotted Brembo rotors
1997 Celica ST (DD) - 17" ADR, ViS Zyclone CF hood, ViS CF hatch, K&N intake, Invader body kit
post Apr 6, 2010 - 10:43 AM
johnnehh
Joined Aug 5, '09
From Oakley, CA
It's my buddy's kid. He works at best buy wiring up stereos and went to college for it and stuff, and he told me hed help me out wiring up the fogs. His wife is at work, so he brought Shyla (the baby) over.
NOW HALP ME.
Haha, I'm going to Les Schwab after school to see if they can see what's up...
post Apr 6, 2010 - 10:49 AM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
i think i have this issue too but my offsets fine
"she can polish my strut bar anytime As long as her blow-off valve's in good order"
post Apr 6, 2010 - 11:19 AM
flyinglizard
Joined Nov 15, '08
From Merced, CA
It's not the toe or an alignment issue because the whole wheel is sucked in as opposed to just one side of it. I'd say it's a lower control arm or some other suspension component that got knocked silly during lowering spring swappage
This post has been edited by flyinglizard: Apr 6, 2010 - 11:19 AM
post Apr 7, 2010 - 2:57 PM
Tech-Nics
Joined Jun 18, '08
QUOTE (johnnehh @ Apr 5, 2010 - 11:37 PM) *
It looks like it might be cause of the fender. If you see in the top picture the fender looks to stick out a little from the low beam head light around the top corner. The second picture shows the fender sitting cleaner and tucked better on the passenger side in the same area of the head light. I could be wrong but I just noticed that...heh
post Apr 7, 2010 - 7:01 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
Eh. Brought it to the bodyshop. Same thing that happened to AJ. $300 to fix. I'm just going to get a spacer I think...
post Apr 7, 2010 - 7:14 PM
D-Man
Joined Jan 18, '08
From Houston
STEP 1: Remove baby (or give it a wrench)
STEP 2: Buy a Heating gun
STEP 3: Heat and hold
STEP 4: Repeat.
STEP 5: fill remainder in with bodyfiller/fiberglass (resin&mcep only)
STEP 6: sand/primer/paint
STEP 7: Replace baby (or remove wrench)
Giving baby's wrenches is a good idea no matter what anyone says. it's SOCKETS that you need to look out for. baby's will swallow that 4MM real quick...
Oh and Philips head screwdrivers are not something you want them learning how to use yet..... My daughter is two, and recently removed my license plate... i haven't found it yet either. I have video for any disbelievers.
Damn D-Man - most impressive.
post Apr 7, 2010 - 7:41 PM
ajmorris1977
Joined Jul 13, '09
QUOTE (johnnehh @ Apr 7, 2010 - 8:01 PM) *
its worth the money to fix it, my tires last a hell of a lot longer now, buts its your car my friend....
post Apr 7, 2010 - 8:22 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
QUOTE (ajmorris1977 @ Apr 7, 2010 - 7:41 PM) *
Well the camber is fine, the tires wear evenly, it's just the look of it.. kindasad.gif
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Okay, you have a bent lower control arm? This isn't something you just fix with a spacer.
post Apr 7, 2010 - 9:57 PM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
Why has nobody thought that Tech-Nics has the RIGHT thought that maybe he has 2 diff. finders? The gt has wider fenders then the st, sooooooo you might have an st fender. Has it ever been replaced?
post Apr 7, 2010 - 11:23 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
QUOTE (hatchy_gt-s @ Apr 7, 2010 - 9:57 PM) *
Uhh.. When they put the car up you can clearly see that it wasn't even from the bottom. Yes, they were replaced, but that isn't the problem.
post Apr 7, 2010 - 11:43 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
how did it look before you got the rotas?
and D-man i call BS Video or it didnt happen!
Lo-Fi Version Time is now: December 4th, 2024 - 8:11 AM
