> Liquid cooled Turbo Exhaust Manifold
post Apr 19, 2010 - 12:03 AM
xlee
Joined Apr 22, '09
From MN
As i was building my water cooled computer, it just dawned on me that no one has ever tried a water cooled exhaust manifold. I think this would drop the engine bay temp by a bunch numbers. And for those that use fiberglass wraps, this will the end of that. smile.gif
I was thinking maybe welding small bases on each exhaust manifold pipe and have liquid running to the radiator much like a computer cooler. I would love to see this for our 5sfe and 3sgte if its already out there!!
This post has been edited by xlee: Apr 19, 2010 - 12:06 AM
Replies (1 - 9)
post Apr 19, 2010 - 12:13 AM
johnnehh
Joined Aug 5, '09
From Oakley, CA
1996 Toyota Celica GT (GT4 conversion) - SOLD :(
2002 Audi A4 1.8T Quattro - Daily Driver
post Apr 19, 2010 - 5:57 AM
BriinumsBo
Joined Feb 6, '08
From Latvia
oil would be better. either way you would need a superior radiator. if the housing cracks, you would be risking an explosion of your diy box.. coolant expands and vaporizes at extreme rate!when pushing the turbo hard, the header/turbo would raise high above 100C and would smoke the coolant into gas instantly..
+1 for idea
1994 MR2 SW20, 1990 Celica ST185, both 3SGTE
turbo celica | celica club .eu | celica gt4 | imports | Toyota GT 86 | Scion FR-S | Subaru BRZ
post Apr 19, 2010 - 8:03 AM
Nartanian
Joined Mar 26, '09
From Minnesota
Please do tell more about your PC build.
"God created turbo lag to give V8's a chance"
post Apr 19, 2010 - 1:09 PM
zonz540
Joined Jul 3, '09
From UT
Isnt the idea with exhaust for it to be at a high temp because then the liquid flow rate out of the exhaust system is higher, giving a lower backpressure and cleaner exit from the system?
post Apr 19, 2010 - 5:36 PM
xlee
Joined Apr 22, '09
From MN
Apparently, Boats have this technology.
http://www.marineengine.com/boat-forum/sho...ad.php?t=289794
anyone in here a marine tech?
My pc is a Intel I7-920 with water coolers of course.
The rest of the other parts are typical gamer's specs.
post Apr 20, 2010 - 10:36 AM
Nartanian
Joined Mar 26, '09
From Minnesota
Nice, I went AMD 965. What video card?
post Apr 20, 2010 - 4:59 PM
QUOTE (xlee @ Apr 19, 2010 - 1:03 AM) *
you want to keep heat IN the exhaust manifold.
heat and the rapid expansion of gasses is what spools the turbo.
the "fiberglass wrap" is actually used to keep heat in the exhaust manifold, not help cool it.
ceramic coating does the same thing. keeps heat in the exhaust manifold, which in turn lowers engine bay temps.
post Apr 20, 2010 - 6:03 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Grimmspeed will ceramic coat anything, and I believe turbo manifolds that they coated showed temps somewhere around 60 degrees. They said they were able to get out after hard driving and grab the manifold with their bare hands.
Ceramic coating +1
**** Photobucket
post Apr 20, 2010 - 6:04 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE (presure2 @ Apr 20, 2010 - 5:59 PM) *
^^ what he said
Breaking Axles...
Lo-Fi Version Time is now: February 17th, 2025 - 8:54 AM
