![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) ![]() |
so a few days ago i went to hook up my new hid bulbs to my fogs, it did not work, at all, i had the black wire running to what i am assuming is the ground under the tensioner and all that and the blue going to the stock power location for the fogs, can anyone help me out?\
![]() Enthusiast ![]() Joined Apr 5, '09 From B.C. Coquitlam Currently Offline Reputation: 5 (100%) ![]() |
are these hids with ballasts? you will need to do some troubleshooting with a multimeter or test light.
Yes they have a ballast and the regular fogs work fine but the hids won't, maybe I need a better ground
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) ![]() |
u should get a bulb, then a separate box (the ballast) the power goes to the box, and the bulbs plug into the box. it will work one of the two ways. make sure the ground is good and if it dont work, swap ground and power
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) ![]() |
Ground under the tensioner?? pics would help a lot
fixed the issue, got a voltage tester and apparently toyota or someone decided to change which was the ground and which was the power on the fogs
Well issue is not fixed, pass sides works, drivers side lights up flickers and then shuts off. Help
assuming its plug and play one the connectors are not fully connected, check all plugs it could be arcing, and maybe ur polarity is reversed. if its none of those use ur voltmeter to check wut the ballast input and output voltages are
all connections are good, they are all soldered together so there is no issue there but like i said it flickers and then dies, if i mess with the ground it will flicker more
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) ![]() |
Did you sand down to bare metal for the ground spot?
![]() Enthusiast ![]() ![]() Joined Jan 16, '09 From Cyprus Currently Offline Reputation: 10 (100%) ![]() |
all connections are good, they are all soldered together so there is no issue there but like i said it flickers and then dies, if i mess with the ground it will flicker more connect the hid directly to the battery! the additional cables cost cents for that... cheers -------------------- ![]() |
i have already tried running it to the battery with the same results, all the grounds were good it was grounded to the ground for the fogs where it was soldered to the piece
did u check ur output and input voltages with ur multimeter yet? this is the easiest way to troubleshoot ur problem.
if ur input V is wrong then its ur power supply output V is wrong its ur ballast it both those are good ur bulb is no good |
Enthusiast ![]() ![]() ![]() Joined Aug 11, '09 From Buffalo, NY Currently Offline Reputation: 15 (100%) ![]() |
did u check ur output and input voltages with ur multimeter yet? this is the easiest way to troubleshoot ur problem. if ur input V is wrong then its ur power supply output V is wrong its ur ballast it both those are good ur bulb is no good @96st:Where did you buy your bulbs from? On EBay, I've had to run through a few sets of bulbs but a seller named xhidoutlet located in North Carolina sells the best replacement HID bulbs you can find. No flickering and for 15.99 shipped you can't beat 'em. Plus, the bulbs actually last - so do their ballasts when they have them in stock. I had one moving around in my engine bay for months and it just went on me last month. I pulled it out and it was scarred to all hell, really took a beating. If it ends up being your bulb, buy from those guys, they've got a quality service going on. -------------------- ![]() |
Lo-Fi Version | Time is now: February 18th, 2025 - 7:47 AM |
