> Radiator fan not running! (overheating), Is it ALWAYS supposed to run?
post Jun 26, 2010 - 8:53 PM
Xvani
Joined Mar 9, '10
From LA
I think I have an overheating problem.. Looking at gauges it looks fine, but it heats up pretty fast (about half way+) and EZlube pointed out that my coolant had rust.
When checking the levels of coolant, it looks like it's completely dry. Might have to add distilled water, as I don't know what it's supposed to look like.
On the fan though. Should it run if it's completely cold? Or does it only turn on once the engine is warm?
Thanks
Replies (1 - 11)
post Jun 27, 2010 - 12:11 AM
Johnnyny
Joined Apr 28, '09
From York pa
its not always supossed to run
post Jun 27, 2010 - 8:17 AM
bad coolant temp sensor possibly, try replacing the two wire one.
post Jun 27, 2010 - 6:33 PM
Xvani
Joined Mar 9, '10
From LA
Thanks guys!
Do I add water to the plastic overflow reservoir on the right, or straight into the radiator where the metal cap is in the middle?
This post has been edited by Xvani: Jun 27, 2010 - 6:33 PM
post Jun 27, 2010 - 6:45 PM
if both are low, add to both.
post Jun 27, 2010 - 6:55 PM
Xvani
Joined Mar 9, '10
From LA
waiiiit, there are TWO places to check? lol. I only know how to check the plastic one!
post Jun 27, 2010 - 7:17 PM
...you just asked which of the 2 to add to so you obviously know there are two places.
post Jun 27, 2010 - 7:50 PM
Xvani
Joined Mar 9, '10
From LA
Not where to check the LEVEL of the middle one.. Only the plastic one smile.gif
post Jun 28, 2010 - 11:49 AM
blu94gt
Joined Mar 23, '05
From Kansas City
I always add water straight to the radiator.
The fan will run more when it's hot out and you're going slow or stopped, especially if your A/C is running. Sounds like you need to drain and flush your radiator if there's rusty crap inside it.
1999 Celica GT
post Jun 28, 2010 - 12:02 PM
Xvani
Joined Mar 9, '10
From LA
Thanks!
Well aware, but I'm selling the car in a couple of days anyway =)
How do I check the radiator coolant level? (middle one - not overflow)
post Jun 28, 2010 - 4:47 PM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE (Xvani @ Jun 28, 2010 - 12:02 PM) *
Thanks!
When it's full, it's full. There's no level, it should just be filled to the top with coolant and distilled water.
1999 Celica GT
post Jun 28, 2010 - 5:12 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
http://www.6gc.net/forums/index.php?showto...mp;#entry781183
God made man....
Everything else...
Made in China
Lo-Fi Version Time is now: December 3rd, 2024 - 3:19 PM
