turbo oil lines question, little help please |
Jul 3, 2010 - 7:04 PM |
Enthusiast Joined Sep 23, '09 From Dartford Kent Currently Offline Reputation: 0 (0%) |
would someone please explain the oil fittings to me please, i can't make sense of it and google yields nothing of use.
what lines and fittings do I need for 7afte? thanks |
Jul 4, 2010 - 10:28 AM |
it depends on what turbo your using, but a generic list would look somthing like this.
for the feed line, your going to need a 1/8th bspt male to 1/8th npt male fitting, that will screw into the block where the stock oil pressure sensor is on the 7a, to allow you to attach a line to supply oil to the turbo. for that you will need a 1/8th ntp to 3an fitting, 2 3an hose ends, and enough stainless braided hose to make the line. for the return, i would suggest no less than a 10an line. (hurley97 has lots of info on fittings and lines in her thread http://www.6gc.net/forums/index.php?showtopic=52444&st=0 ) youll need to drill and tap your oil pan for the return fitting like this: i believe that pic is either 1/2 or 3/4npt to 10an. another fitting for the turbo flange (size will depend on the turbo) and again to hose ends and SS hose. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Jul 5, 2010 - 5:56 AM |
thanks man, pretty sure I can manage that
Lo-Fi Version | Time is now: November 29th, 2024 - 1:27 PM |
