> air intake?
post Aug 3, 2010 - 2:23 PM
zakinabox
Joined Jul 28, '10
From Wrentham, MA
well i just installed my air intake, short ram? like im said first project car, and installed it myself... hopin i did everything right... had a left over hose and a nipple comin off the intake piping tht i had no idea wat to attatch because there was nothing i pulled from the stock intake that resembled it in use....
any input would be awesome, dont want to kill my celica after a month
look good?
Replies (1 - 9)
post Aug 4, 2010 - 9:50 PM
zonz540
Joined Jul 3, '09
From UT
its an unused nipple. I just wrapped mine in enough good electrical tape to seal it. I didnt have the stuff to weld aluminum.
post Aug 4, 2010 - 10:07 PM
mkernz22
Joined May 10, '10
From MA
the left over hose attaches to the nipple that you didn't use. I just installed my weapon-r today, but i had to extend the extra hose
also, did you drill a hole and put the air sensor in? you will possibly need that installed to pass inspection
This post has been edited by mkernz22: Aug 4, 2010 - 10:11 PM
post Aug 4, 2010 - 10:35 PM
zakinabox
Joined Jul 28, '10
From Wrentham, MA
QUOTE (mkernz22 @ Aug 4, 2010 - 10:07 PM) *
air sensors in, install kit came w/ a hole and gromet in it already, its on the back side, had to relocate the wiring to reach and fit the pipe.... deffinatly upgrading tht air intake at some point but thought why not blow the $25 now for something funesk
post Aug 4, 2010 - 10:42 PM
mgnt232
Joined Mar 16, '09
good job smile.gif should a got a CAI IMO smile.gif but still looks good. And the nipple thing, is on mine as well, but mine also came with a little rubber cap, i just put on it. You should also drill out the hole for your intake temp sensor.
I had a pic of my intake sensor, but i cant find it.
You can see in this pic, the nipple on mine, and the little black cover i put in it, I assume that electrical tape will work just the same smile.gif GL
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Aug 4, 2010 - 11:09 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Oh god, its like Superman took a dump in your engine bay.....
**** Photobucket
post Aug 4, 2010 - 11:14 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
you could also do what i did to mine and add hose to the end of that filter, looks like a spectra filter like mine, anyways take and run it through the old air box hole and down into the front fender, it will pick up some more cold air.
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Aug 4, 2010 - 11:16 PM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
QUOTE (mgnt232 @ Aug 4, 2010 - 11:42 PM) *
QUOTE (95CelicaST @ Aug 5, 2010 - 12:09 AM) *
This post has been edited by hatchy_gt-s: Aug 4, 2010 - 11:17 PM
post Aug 4, 2010 - 11:33 PM
Nartanian
Joined Mar 26, '09
From Minnesota
"God created turbo lag to give V8's a chance"
post Aug 5, 2010 - 1:37 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Go to Pep Boys or Auto Zone and they have little rubber caps that you can cover that nipple with. Why not spend an extra 2-3 bucks so you're not ghetto rigged?
June '12 COTM
'95 AT200
Lo-Fi Version Time is now: January 11th, 2025 - 5:04 PM
