> 7a rebuild and Vortech Supercharger
post Aug 11, 2010 - 8:36 PM
al94st
Joined Dec 30, '09
From Wilmington, NC
So first off, I've been using this forum a lot for reference and information in the past few months and it's a great tool for anyone who owns a Celica, so thanks to everyone who puts up good information.
I'm in the process of rebuilding my 7afe. It had 136000 on it when i pulled it out, but it hardly looked like 30000 were on it once i opened it up except for some oil sludge. I purchased a V-5 vortech f-trim to put on after i get the car running again, but I figured I'd share a few pics of the rebuild and update some more when I get to the fun stuff.
Pulled the engine in Feb, (i travel around the world a lot, so I've been off and on with this project) brought block and head to my machinist. Block only needed a fine hone. Head didn't need much, but had a valve job done just to freshen it up since 16 yrs on the valve springs is probably enough. Started rebuilding on Wednesday and relaxed today, I might finish rebuilding tomorrow.
Block painted and piston one reinstalled.
nice picture of the little 7a rods
head and cams installed, water pump on
timing belt installed
This post has been edited by al94st: Nov 1, 2011 - 5:35 AM
9 Pages V   1 2 3 > »
Replies (1 - 19)
post Aug 12, 2010 - 5:18 PM
celica74
Joined Feb 8, '10
From North Carolina
wow. very unique. Have never heard of anyone putting a supercharger on a 7a. keep the info comming
post Aug 14, 2010 - 9:22 PM
95celicastLSR
Joined Nov 16, '06
From Findlay,Oh
i have thought about this because of instant boost and great low rpm tq. this may turn out to be a start of a whole new way to power the 7a"S..... great work man keep us up to date
post Aug 14, 2010 - 9:44 PM
Johnnyny
Joined Apr 28, '09
From York pa
if you want some low rpm power get some cams work done
post Aug 15, 2010 - 8:58 AM
al94st
Joined Dec 30, '09
From Wilmington, NC
As far as I've seen the stock cams are designed for low rpm power and efficiency, that's part of why the 7a gets sluggish in the high RPMs. Grinding the cams is going to give you better power in the upper RPM range. I don't think it'll do too much for low RPM hp and torque.
post Aug 15, 2010 - 9:27 AM
I'm very interested to see how this'll turn out, I was under the impression that a supercharger on a 7A was impossible due to the positioning of the intake manifold.
post Aug 15, 2010 - 11:36 AM
Nartanian
Joined Mar 26, '09
From Minnesota
This should prove to be interesting.
"God created turbo lag to give V8's a chance"
post Aug 16, 2010 - 12:30 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
the v5 might be a little big for the 7a, but props on building the brackets to make it all fit. it's a good blower.
post Aug 22, 2010 - 7:37 AM
al94st
Joined Dec 30, '09
From Wilmington, NC
Quick update. Yesterday I started and timed the engine without any problems. I'll try to get a couple pictures of the car up in the next few days. Once I get the car back on the road I'll break in the engine then start installing the blower.
post Aug 22, 2010 - 8:17 AM
Tom_SS2
Joined Jun 12, '09
From Hull, England
i heard a 7A-GZE had been done before using pars from the 7A-FE and the 4A-GZE, but i suppose you're trying for a 7A-FZE?
edit;
quick google finds a you tube vid of a 7A-FZE
http://www.youtube.com/watch?v=8AafhU0qiXE...feature=related
post Aug 22, 2010 - 8:43 AM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Nice vid find, GL with your build bro, this is def different.
post Aug 22, 2010 - 11:39 AM
cheela
Joined Feb 2, '07
From Berlin, WI
very interesting indeed. I'll be peeking into this thread to see how it goes. Good Luck with everything. hope it turns out well.
post Sep 2, 2010 - 7:43 AM
al94st
Joined Dec 30, '09
From Wilmington, NC
I've put about 90 miles on it since rebuild. I also installed my megan coilovers. Very happy with them. I had a header on the car when I put the engine back in, but I decided to take it off until I have more time to mess with the exhaust. I plan to go 2.5". Current setup is stock with supertrapp muffler. I'll probably start messing with the blower in a month or so.
This post has been edited by al94st: Mar 18, 2011 - 8:18 PM
post Oct 28, 2010 - 10:11 PM
al94st
Joined Dec 30, '09
From Wilmington, NC
Quick update on this. Haven't given up on the project, just on hold for awhile because I'm in the process of relocating to NC. Just installed a new exhaust system.
In order to make the Vortech fit nicely, I need to make a solid motor mount for the passenger side that attaches further back on the frame to open up some room and help with the supercharger mounting. Then the relay box and windshield washer filler tube need to be moved (which is simple). It might just fit under the hood after that.
post Oct 30, 2010 - 5:33 PM
celica74
Joined Feb 8, '10
From North Carolina
What part of NC? im located just outside of raleigh
post Oct 30, 2010 - 9:31 PM
al94st
Joined Dec 30, '09
From Wilmington, NC
Wilmington
post Nov 2, 2010 - 6:00 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Nice choice of wheels! I dunno how to explain it, but they flow nicely with the body lines. I can't wait to see a supercharged 7A, that'll be cool.
June '12 COTM
'95 AT200
post Nov 2, 2010 - 6:05 PM
celica74
Joined Feb 8, '10
From North Carolina
might have to take the 2 1/2 hour drive to check it out when your all done
post Nov 2, 2010 - 6:29 PM
al94st
Joined Dec 30, '09
From Wilmington, NC
QUOTE (HectortheRican @ Nov 2, 2010 - 6:00 PM) *
Thanks, they're 15x7 Drag Dr-17's. They're like 14 lbs I think. Discounttire.com sells them for 100 a piece including the hubcentric rings and lug nuts.
QUOTE (celica74 @ Nov 2, 2010 - 6:05 PM) *
Might take a little bit frown.gif , but that'd be cool.
post Nov 2, 2010 - 8:45 PM
HectortheRican
Joined Dec 26, '09
QUOTE (al94st @ Nov 2, 2010 - 5:29 PM) *
Haha thanks, I'll keep that in mind when looking for replacements. Right now I have 17x7.5 Drag DR-19's.
June '12 COTM
'95 AT200
9 Pages V   1 2 3 > »
Lo-Fi Version Time is now: November 29th, 2024 - 6:17 PM
