> can i instal ABS?
post Aug 12, 2010 - 1:52 AM
Justin8358
Joined May 28, '10
From Oakley, Ca
94' Celica GT
no ABS
can i add it?
Replies (1 - 8)
post Aug 12, 2010 - 3:29 AM
Johnnyny
Joined Apr 28, '09
From York pa
im sure you could but it would suck to do change over a lot of stuff
post Aug 12, 2010 - 4:38 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
huh....i thought abs was standard on all gt's.....i got a 94 and have abs hogging all this space up.
post Aug 12, 2010 - 4:39 AM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (Spider77 @ Aug 12, 2010 - 5:38 AM) *
nope was an option
post Aug 12, 2010 - 11:48 AM
Justin8358
Joined May 28, '10
From Oakley, Ca
anyone have any idea how i would do it?
This post has been edited by Justin8358: Aug 12, 2010 - 11:49 AM
post Aug 12, 2010 - 1:05 PM
Johnnyny
Joined Apr 28, '09
From York pa
it would really be easier to buy a celi with abs u would need everything
post Aug 12, 2010 - 2:40 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
my auto 96 had abs.
my manuel 95 doesnt.
i miss abs so freaking much!!
i was gonna swap it from my 96 to 95 but its sooo much
post Aug 12, 2010 - 6:45 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
You need to source and/or replace:
sensors
front and rear hubs
rear wheel bearings
front axles
dust shields for front axle seals
wiring
abs ecu
abs control unit
brake master cylinder
and basically all the brake lines that go along the firewall from the master cylinder to the control unit up until the splitters that go into the wheel wells and to the rear
much easier to remove the system. The sensors almost always go bad so if you try to get used ones they will either be bad and/or stuck in the hub and replacing the sensors with new ones will cost you about $400 each. And getting to the lines on the firewall with the motor in the car is not going to be easy. But that won't be the worst part, the worst will be wiring it all in to a car that doesn't have the wiring for it. Even if you get the whole dash harness you would still need to take the dash out to install it, not to mention the wiring outside that goes to the sensors...
but yes, it can be done.
This post has been edited by hurley97: Aug 12, 2010 - 6:47 PM
I <3 Dustin---07/16/06
post Aug 13, 2010 - 11:25 AM
Justin8358
Joined May 28, '10
From Oakley, Ca
QUOTE (hurley97 @ Aug 12, 2010 - 7:45 PM) *
sensors
front and rear hubs
rear wheel bearings
front axles
wiring
abs ecu
abs control unit
so yeah...
im not gonna even try then.
haha
Lo-Fi Version Time is now: November 30th, 2024 - 12:14 PM
