reverse lights not working |
Aug 13, 2010 - 3:20 AM |
Enthusiast Joined Aug 13, '10 From Australia Currently Offline Reputation: 0 (0%) |
iv got a 1994 st204 automatic my reverse lights are not working, i checked globes, fuses, checked wiring back half way inside the car.
iv had a look at the reverse switch on the gearbox. but im unsure which plug is the reverse switch. i believe its the 2 wire plug next to the linkages. i have tried bridging the wires on the two pin plug (next to linkages) and reverse lights still dont work. i may have the wrong plug. also does anyone have a electrical wiring diagram for this model. thanks |
Aug 30, 2010 - 12:38 PM |
Enthusiast Joined Jan 6, '03 From Philadelphia Suburbs Currently Offline Reputation: 13 (100%) |
iv got a 1994 st204 automatic my reverse lights are not working, i checked globes, fuses, checked wiring back half way inside the car. iv had a look at the reverse switch on the gearbox. but im unsure which plug is the reverse switch. i believe its the 2 wire plug next to the linkages. i have tried bridging the wires on the two pin plug (next to linkages) and reverse lights still dont work. i may have the wrong plug. also does anyone have a electrical wiring diagram for this model. thanks I was in the same boat, I went to Toyota Dealership, and after a rape and pillaging ($175) for a reverse switch and install, they worked again. Although my butt still hurts. |
Lo-Fi Version | Time is now: November 24th, 2024 - 2:51 PM |
