> Weird braking at high speeds, NEW TOPIC! how to replace rotors and pads
post Aug 19, 2010 - 11:04 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
When I'm going above 55 or so and I apply the brakes, the car seems to shake... the pedal shakes and the steering wheel shakes. Lower speeds, it's just fine. What could that be?
This post has been edited by HectortheRican: Aug 23, 2010 - 2:09 PM
June '12 COTM
'95 AT200
Replies (1 - 19)
post Aug 19, 2010 - 11:07 PM
rotors are grooved.
time to replace the pads and either cut the rotors or get new ones.
post Aug 19, 2010 - 11:47 PM
HectortheRican
Joined Dec 26, '09
What does that mean?
June '12 COTM
'95 AT200
post Aug 20, 2010 - 1:42 AM
zonz540
Joined Jul 3, '09
From UT
When you press the brakes, they rub on your rotors/rear drums. The friction wears down the brake pads as well as the rotors/drums. Eventually, the spots that arent rubbed by anything wont be worn down and they will form a lip around where the brake pad does press. You need to get rid of this lip by shaving off the rest of the rotor to wear it all down to the same surface or get new rotors.
Take the rotors to an auto shop and get your brake rotors milled or go to autozone and replace them. Getting them turned will cost you about $20 per rotor. Autozone will charge about $40-$50 per rotor new.
post Aug 22, 2010 - 7:05 PM
marinos
Joined Aug 17, '10
I also thing the problem might be the rotors I have replaced mine and the car feels great. I had cut them the first time but later i put new ones at the front and it feels great mine also was shaking and at high speeds without to apply the brakes.
post Aug 22, 2010 - 9:20 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
warped rotors
2nd Gen 3s-gte.... It lives!
97celiman
post Aug 23, 2010 - 1:40 AM
SoDo
Joined Dec 16, '07
From Chicago, IL
QUOTE (Stambo @ Aug 22, 2010 - 9:20 PM) *
warped rotors
x2
1999 Celica GT Hatchback
post Aug 23, 2010 - 7:50 AM
jtmlb3k
Joined Jun 11, '10
From Los Angeles
I had the same issue. It's exactly what everyone is saying. I took mine to get replaced but the shop ended up just shaving them (said they were off because the car sat for most of the winter in New England cold) and now they're fine. It didn't cost me more than $50 for all 4 to be shaved, plus a tire rotation.
post Aug 23, 2010 - 9:03 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
yea... it isn't worth resurface rotors. buy new!
post Aug 23, 2010 - 10:13 AM
HectortheRican
Joined Dec 26, '09
That's what I'm planning on! It'll have to wait a bit though, I'm jobless at the moment because I had to move for college
June '12 COTM
'95 AT200
post Aug 23, 2010 - 2:10 PM
HectortheRican
Joined Dec 26, '09
I like to do as much as I can myself, so could someone give me a how-to on replacing rotors and pads? Thanks in advance.
June '12 COTM
'95 AT200
post Aug 23, 2010 - 5:06 PM
RockyMountainCel...
Joined Aug 11, '10
From Alberta
QUOTE (HectortheRican @ Aug 23, 2010 - 3:10 PM) *
Can't give you a how-to since I've never done it before on a Celica but I can say it should be fairly easy. I did the brakes on my 2003 Elantra GT and after wrecking 2 calipers I finally got the 3rd to work. I failed on the first caliper for over tightening the brake line, and the other one I ripped the rubber boot cause I didn't know there was such a tool as a "rear caliper tool". I assume the Celica is no different and you will require a rear caliper for the rears. Otherwise it's pretty straight forward, you have to remove a part of the caliper off the rotor to remove the rotor and place the new pads. Make sure that whatever brakes you get that you properly bed them in, this involves specific braking for about 10-20 mins depending what pads you get. I personally recommend the Hawk HPS pads if it is strictly a street car. If you do any auto-x or lapping events I recommend the Hawk HP+ pads, I had them on my Cobalt and once they are warm they are like glue, I LOVED them.
This post has been edited by RockyMountainCelica: Aug 23, 2010 - 5:07 PM
2009 Chevy Cobalt SS Turbo "Torque Monkey" SOLD
1993 Honda Civic Si "Mean Green Cornering Machine" Track Whore
1995 Toyota Celica GT "Baby Supra" Daily Driver
post Aug 23, 2010 - 8:49 PM
zfjohnson07
Joined Apr 11, '09
its easy, take off the brake caliper, and then take off the mounting bracket that holds the cailper in place, either get a hammer and knock off the rotor or get 2 screws and stick them in the holes on the rotor to get it to loosen up..
post Aug 24, 2010 - 12:55 AM
Rusty
Joined Nov 5, '07
From New Zealand
do you have ABS?
post Aug 24, 2010 - 1:38 AM
HectortheRican
Joined Dec 26, '09
QUOTE (Rusty @ Aug 23, 2010 - 11:55 PM) *
do you have ABS?
Yes, I do.
June '12 COTM
'95 AT200
post Aug 25, 2010 - 1:54 AM
Rusty
Joined Nov 5, '07
From New Zealand
bleed your system (properly with a bottle and hose) when you are romoving the calipers. If you dont you will push the fluid back up into the ABS motor and do damage.
post Aug 25, 2010 - 8:18 AM
HectortheRican
Joined Dec 26, '09
QUOTE (Rusty @ Aug 25, 2010 - 12:54 AM) *
So before I remove the calipers, bleed?
June '12 COTM
'95 AT200
post Aug 26, 2010 - 1:04 AM
Rusty
Joined Nov 5, '07
From New Zealand
as you are pushing the pads out and removing the calipers. Since you dont want to force any fluid back up the system.
post Aug 26, 2010 - 10:29 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Its good practice to bleed the system while you are changing pads anyhow. I think its a lot easier with no wheel in the way.
post Aug 26, 2010 - 3:58 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (Spider77 @ Aug 26, 2010 - 10:29 AM) *
If you are gonna do that you might as well flush the entire system by pumping a bottle of cheapo brake fluid through it before you put the good stuff in as well
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
Lo-Fi Version Time is now: December 3rd, 2024 - 5:52 AM
