> rear brakes clunk
post Aug 22, 2010 - 7:43 PM
marinos
Joined Aug 17, '10
Hello,
I am listening clunk noises from the back of my car under braking. Actually as i brake and when the car is close to stop just before stop spinning the wheels I listen clunk noises and from the both sides of the car at the rear. I am not sure if this is brake problem or something else but i guess is the brakes because that happens only under braking.
This noises I m listening I have them since bought the car and I don't know if this is related with the apex lowering springs that my car had from when I bought it.
Thanks for taking your time and sorry for my English.
Replies (1 - 4)
post Sep 10, 2010 - 11:22 PM
sxy6g
Joined Feb 24, '10
From sydney australia
I don't know what the problem is, but I can tell you it's not the suspension. I have standard suspension and I get the same click as your describing. so I hope someone has the answer so we can both have the proble fixed...
*PRAISE THE LOWERED*
post Sep 12, 2010 - 6:08 PM
marinos
Joined Aug 17, '10
QUOTE (sxy6g @ Sep 11, 2010 - 12:22 AM) *
I looked carefully and I found that the inner break pads are moving in the caliper about 1cm but I dont know if this is normal. And when I move the pads with my hands and make it hit on the upper side of the caliper (the way that hits when the car is going forward)i hear that clunk just with my hands. So I will check how worn are my rear break pads or the springs. I thing you should check this to. But still I dont now if this is the problem I hope I have helped you.
post Oct 7, 2010 - 7:10 AM
sillica
Joined Sep 18, '07
From nsw
i had the same issue once, your brake caliper pins need greasing do all four calipers, after i did that the problem was resolved
post Oct 16, 2010 - 4:27 AM
marinos
Joined Aug 17, '10
QUOTE (sillica @ Oct 7, 2010 - 7:10 AM) *
thanks sillica!
Lo-Fi Version Time is now: November 30th, 2024 - 2:39 PM
