Enthusiast Joined Aug 24, '10 From NY Currently Offline Reputation: 1 (100%) ![]() |
I want to know how you install the hid kits in the celica 95 on both high and low beams so both can be kept on at the same time. or i is it a bad idea?
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 10, '09 From Louisiana Currently Offline Reputation: 5 (100%) ![]() |
Uhm should be plug and play.... Ballast and all.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) ![]() |
when you have the low beams on, and then then you turn the high beams on, the low beams stay on with the high beams. it's how our cars are designed
I know but let say i connect all four headlights with an HID kit each would all of them work at the same time? btw whats a good cheap HID kit i can purchase
DDMTuning, its like 60$ a kit with a lifetime warranty. Depending on what model and how many watts. And i dont understand what your asking... are you asking if you get 1 Ballast can you hook up 4 headlights to it....
HID kits are for either high or lows. So you will have to buy two kits, one for the high beams and one for the low beams.
Each kit comes with two converters, one for each of the head lights. The converters just plug into the existing high and low beam plugs. I hope this clears thing up because you can't connect all four headlights to one converter. |
Ok, so your saying i need two kits which should include four converters?
yes exactly, each kit includes two converters, so four altogether.
http://www.hidxenonheadlights.com/Toyota-Celica-HID-Kits/ |
thanks!!!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) ![]() |
Dumbest idea ever. HIDs in a halogen housing = ricer who doesn't care about the safety of others.
Save your money kid and buy projectors. Then get your fancy HID kit. Until then by some Silverstar bulbs or some Phillips bulbs. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Lo-Fi Version | Time is now: February 17th, 2025 - 4:41 PM |
