> noise from the front driverside wheel
post Aug 30, 2010 - 12:10 AM
pnoywitmustrdsau...
Joined Mar 28, '05
From California
so i change my driverside front axel because it was making that clicking noise when you turn left. but after i changed it the noise increase! im suspecting the wheel bearing, but can anyone think if it to be something else?
Replies (1 - 8)
post Aug 30, 2010 - 1:17 AM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
Too many things it could be, check for play in the wheel and if the axle nut is tight and it has play the bearing is most likely the cause, although check it doesn't have play from the ball joint or tie rod.
Make sure you didn't under tighten the nut or over tighten is as it damages the bearing, torque it to 137ft from memory.
post Sep 1, 2010 - 6:24 PM
pnoywitmustrdsau...
Joined Mar 28, '05
From California
yea so i pulled the hub apart to get to the bearing and im quite certain there should be a plastic holder for the bearing correct? but the problem is is there is no more plastic holder thingy. on top of that bits and pieces of the plastic holder thing came out!
post Sep 2, 2010 - 10:26 PM
Euphoria
Joined May 6, '08
QUOTE (pnoywitmustrdsauce @ Sep 1, 2010 - 6:24 PM) *
I don't know what you mean by plastic holder, in the middle of the hub is the bearing, with 2 seals on either sides, I assume you've taken the hub off but the best way to check is to move the flange (thing with wheel studs thats inside the hub) sometimes you can't tell theres play until you move that bit.
post Sep 2, 2010 - 11:31 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
Ya I'm having the same problem currently, replaced the wheel hub and bearing along with a half shaft, but the noise is louder than before, I did make sure the axle nut was touqued to 137... My next thought is maybe the rotor is rubbing on the dust shield.
post Sep 3, 2010 - 6:07 AM
Euphoria
Joined May 6, '08
Could even be the gearbox, if there is no play anywhere under there and its too hard to find the noise put the car in the air and drive it, get near it and you will know tongue.gif.
post Sep 3, 2010 - 11:49 AM
zfjohnson07
Joined Apr 11, '09
i get a clinky noise when i turn left, because when i put a new wheel hub on i didnt tighten that bolt good enough so it had room to move and screwed me, so the 2nd time thought it was a bearing but no its the same damn thing..
post Sep 5, 2010 - 12:29 AM
pnoywitmustrdsau...
Joined Mar 28, '05
From California
problem fixed. it was the wheel hub and wheel bearings. replaced the hub and wheel bearings and had a machine shop press the bearing into the knuckle for me all in all about 200 bucks. well worth it!!!!
post Sep 5, 2010 - 12:35 PM
zfjohnson07
Joined Apr 11, '09
wow thats too much money i got wheel bearing, hub and pressed for 40
Lo-Fi Version Time is now: November 25th, 2024 - 1:43 PM
