> need help with shift cables
post Sep 11, 2010 - 8:19 AM
Scosh
Joined Mar 13, '10
From New Iberia
Hey 6gc, i finally got my hands on a pair of shift cables for my 98 GT. my question is how hard is it to change up the shift cables and how long should it take. I have never done this and i would be greatful if anyone could guild me through the process.
Replies (1 - 12)
post Sep 12, 2010 - 8:36 PM
ZGear
Joined Feb 16, '07
From BP, MN
Take off your center console, you may have to remove the lower driver side dash and the passenger glovebox to access the bolts holding the center console in, unless you know how to without removing a ton of stuff. Disconnect the cables from the tranny and the shifter and pull the cables out, be careful not to stretch the cables, there's a boot that securely fastens the cable to the frame. It's a rubber piece that looks like a square-ish rectangle with two hole tunnels.
Anyone else wanna shine in?
post Sep 20, 2010 - 8:27 PM
Scosh
Joined Mar 13, '10
From New Iberia
Ok so im on the last step of installing my new shift cables. The only problem now is trying to making them fit into the latches in the engine bay. I had problems today trying to make them fit but was unsuccessful. Anyone have any tips?
post Sep 22, 2010 - 12:29 AM
atmosfear
Joined Sep 20, '10
From Kansas City, MO
Hey there, did u pull the cables out through the firewall, or in towards the interior? More than likely, you'll need to run the cables out from the inside of the car. Trying to shove them back thru the firewall just doesn't work, and that rubber "stabilizer " piece needs to be cut above each hole to allow u to move it where you need it, after you've fed the cables thru... hope that helps..
post Sep 23, 2010 - 3:28 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
use the search button please. detailed reply in this thread on the 2nd page of this section, its pretty self explanitory to the normal person. unless you're special which i truly think you're not thumbsup.gif
http://www.6gc.net/forums/index.php?showtopic=75646
pull cables downward toward the exhaust. there's more cable on that end anyways
This post has been edited by 808celica: Sep 23, 2010 - 3:29 AM
post Sep 23, 2010 - 6:29 AM
Scosh
Joined Mar 13, '10
From New Iberia
I have the old cables out and im trying to put the new ones in. The only problem is trying to get the ends that go in the engine bay to fit where they belong bc the cables are hard to work with(to me at least). biggrin.gif
post Sep 24, 2010 - 9:12 PM
97lestyousay
Joined Jul 7, '03
You should be able to push down on the cable, just enough to get the clip started, tap the clip down lightly with the handle of a hammer,
it should go right on.
JDM guy made me do it.
post Sep 24, 2010 - 11:30 PM
Scosh
Joined Mar 13, '10
From New Iberia
I have them in and i have a big problem. My friend was trying to help me put in the pins for the ends of the cable and he dropped and lost the one that holds the shift ball and cable together. Is there anything i can do for a quick fix?
post Sep 25, 2010 - 9:50 AM
97lestyousay
Joined Jul 7, '03
when I installed my short shifter, I dropped one and used a clip from the body of an rc car, just until I got another.
post Sep 25, 2010 - 9:58 AM
QUOTE (97lestyousay @ Sep 25, 2010 - 10:50 AM) *
yup, RC body clips work perfectly!
post Sep 25, 2010 - 1:30 PM
Scosh
Joined Mar 13, '10
From New Iberia
But the one that is missing is the one with the two prongs, will the rc clip still work?
post Sep 25, 2010 - 8:30 PM
97lestyousay
Joined Jul 7, '03
I thought you were talking about the one at the very end of the cable where the ball socket slides on the shift linkage, the one that is
basicly a bent piece of wire.
If you are talking about the flat two prong cable retaining clip, the one that holds the cable in the bracket, no an rc body clip
won't work for that.
post Sep 26, 2010 - 12:36 AM
Scosh
Joined Mar 13, '10
From New Iberia
Ok thanks for the info everyone. I greatly appreciate it.
Lo-Fi Version Time is now: January 9th, 2025 - 5:14 PM
