> Shifter bushings, Brass Bushings
post Oct 7, 2010 - 8:50 AM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
First question, will upgrading my shifter bushings really make that big of a difference? i already have the 7th get shifter and aluminum base bushings for my shifter, so how much difference is there?
and will these bushings work? i know they say they will fit a 7th gen celica, tc, yada yada, but alot of the parts off the 7th gen fit our cars, here is the link
2001 Solar yellow Lexus IS300
Replies (1 - 11)
post Oct 7, 2010 - 9:41 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Those will fit. I have them on my MR2 and they make a BIG difference. Can't recommend them enough.
**** Photobucket
post Oct 7, 2010 - 11:01 AM
tony55343
Joined Aug 18, '10
From champlin,MN
I have a set for sale for $20 shipped, exact same thing brand new. Look in for sale section I still have the kit available.
post Oct 7, 2010 - 11:04 AM
klue
Joined Mar 8, '10
From Great White North
It depends on what you are considering a BIG difference. Will you knock .5sec off your 1/4 mile...probably not. But will the gearbox feel and engage more directly yes. If your shifter bushings are already worn then it would make a more noticeable difference. But really for under 50 bucks what can you be expecting???
post Oct 7, 2010 - 12:42 PM
mak5603
Joined Oct 20, '08
QUOTE (klue @ Oct 7, 2010 - 11:04 AM) *
Not all about power numbers or times. Small mods such as these, polyurethane motor mounts, polyurethane bushings, etc. are just better for the overall feel and performance of the vehicle.
2014 Toyota Rav4 XLE
post Oct 7, 2010 - 5:37 PM
azn87
Joined Aug 2, '06
From bay area
Can someone tell me, I just installed a trd short shifter, do they come with new bushing or can I use this
post Oct 7, 2010 - 10:03 PM
96stgreendemon
Joined Oct 7, '09
did you get a trd quick shifter, or just the 7th gen short shifter? just the shifter comes with purple aluminum bushings that go under the shifter assembly, these go in the engine bay basically right where the shift cables connect to the transmission
post Oct 8, 2010 - 12:58 AM
TRDGT4
Joined Mar 3, '08
From New Zealand
you can also fitted small bearings in the end of the shifter cables or so I have been told maybe Skate board ones??
_______________May COTM 2011_______________
post Oct 8, 2010 - 2:47 AM
Johnnyny
Joined Apr 28, '09
From York pa
im buying these tomorrow 9 bucks i cant loose now i need a trd short shifter...
post Oct 8, 2010 - 2:57 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
QUOTE (TRDGT4 @ Oct 8, 2010 - 1:58 AM) *
That is actually not a bad idea at all, not to sure if they inner diameter will be small enough for the pin of the shift linkage tho?
2nd Gen 3s-gte.... It lives!
97celiman
post Oct 8, 2010 - 4:10 PM
klue
Joined Mar 8, '10
Ive use roller blade wheel bearings, but they dont last the canadian winters.
post Oct 12, 2010 - 5:19 AM
97lestyousay
Joined Jul 7, '03
QUOTE (Stambo @ Oct 8, 2010 - 12:57 PM) *
The inner diameter of standard skateboard bearings is about .314", slip fit for a 5/16 shaft. outer diameter is about .866 with a thickness of about .275".
They sell 8mm but I don't know much about them except they are expensive and used mostly on precision downhill trucks.
JDM guy made me do it.
Lo-Fi Version Time is now: February 17th, 2025 - 1:46 AM
