Oct 23, 2010 - 8:49 PM
Enthusiast ![]() Joined Nov 21, '05 From Quebec Currently Offline Reputation: 0 (0%) |
when I starting without wire on spark plug the engine turn very well and smooth
so when I plug 4 wire or only one no matters 1,2,3 or 4 cylinder ....the starter block and stop... have some explosion so the engine can't start ...he try so can't go over 600rpm I think it's fire trouble ....part or wiring??? I play with distributor and don't help It' 3rd gen 3sgte st205 swap brand new bkr6ep8 have 2 coil... mr2 94 (90919‑02197) and st205 (90919‑02209) have 2 ignitor (89621-26010) have 2 ecu... mr2 94 (89661‑17460) and st205 (89661‑2B840) st205 only code 54 and mr2 have no code when I starting without wire on spark plug the engine turn very well and smooth so when I plug 4 wire or only one no matters 1,2,3 or 4 cylinder ....the starter block and stop... have some explosion so the engine can't start ...he try so can't go over 600rpm I think it's fire trouble ....part or wiring??? I play with distributor and don't help It' 3rd gen 3sgte st205 swap brand new bkr6ep8 have 2 coil... mr2 94 (90919‑02197) and st205 (90919‑02209) have 2 ignitor (89621-26010) have 2 ecu... mr2 94 (89661‑17460) and st205 (89661‑2B840) st205 only code 54 and mr2 have no code timing and firing order look good! -------------------- Celica GTS turbo 1994
3sgte genIII Ct20b |
Oct 23, 2010 - 10:45 PM
the starter is block by detenation for sure... have bent electrode on spark plug #3
| Lo-Fi Version | Time is now: June 10th, 2026 - 4:18 AM |
