> V_D's Custom Gas lid, k this is some stuff/problems i came across
post Oct 26, 2010 - 1:05 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
First it was the chrome gas cap that came with the gas lid. It was perfect until I started to hear hissing noises coming from the cap after a 30min drive, each and everytime. I pm'd him about it and he said give it time as it's still new. Sadly it didnt solve so i used my stock cap. I only use the chrome cap during car shows and meets.
How I came to recognizing the problem?
After my daily commute I smelled gas and heard hissing noises coming from my cap. Then noticed my gas mileage dropped significantly. The noise is heard everytime the car was just turned off. Its like when you go to fill up gas and when you uncap the cap you get that HISSSSS noise from the back pressure.
Second problem due to a faulty design,
First occurance is by Herosblade. The spring mechanism to pop the lid after the lid switch is hit BROKE!
Pretty much you pull the lever and your gas lid doesn't open. This is BAD! when you're by yourself and you don't have an extra hand and NEED GAS!
This JUST happened to me as is the WORST feeling in the world when your gas light is on. You can't get the lid open, you're at the pumps that very moment and your house is 45mins away frown.gif
Temporary solution.....wedge something between the lid and the rear qaurter fender, pop the gas lever, and quickly catch the gas lid before it drops back into place T__T OR you can ask someone to pop the lever when you have your fingers pulling on the gas lid.
I don't know how it broke in the first place as Im very careful with everything installed on the car except my coils wink.gif
SOLUTION!!!
DO THIS BEFORE IT HAPPENS
Simply get spring, mix some epoxy, and do as the pic is biggrin.gif Problem solved. You will never be stuck at the pumps trying to get the damn lid open.
I still haven't solved the gas lid problem, both Herosblade and I have taken off the chrome lid when daily driving our car. WE DO still use the chrome cap on special occasions.
********NOTE THIS THREAD IN NO WAY IS PUTTING V_D'S WORK DOWN. HE IS A PREMEIR 6GC DEALER. I'M JUST GIVING A HEADS UP TO EVERYONE WHILE PROVIDING SOLUTIONS********** I STILL SUPPORT HIS PRODUCTS AND I DONT MEAN ANY HARM
Replies (1 - 6)
post Oct 26, 2010 - 2:21 AM
Johnnyny
Joined Apr 28, '09
From York pa
good to know i was thinking of getting one of these eventually
post Oct 26, 2010 - 9:05 AM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
mine did the same thing with not wanting to open, fixed it a similar way, but never had the cap
2001 Solar yellow Lexus IS300
post Oct 26, 2010 - 1:26 PM
chacha
Joined Dec 29, '05
From So-Cal
i just test fit my and it doesn't spring out too well...i have to use a flat to pry it out a bit...i left the stock on instead.
post Oct 26, 2010 - 4:03 PM
vincent_doggy
Joined May 25, '06
From Hong Kong
Regarding the chrome cap issue, is the plastic O Ring still in place?
I don't mind to send you another chrome cap, if still encounter the same issue.
Simply click here and find the one near ya
http://www.mapquest.com/maps?state=HI&cat=Lottery+Agents
The "Spring" on mine also broken, as no self-serve Gas station here in Hong Kong; I couldn't feel your pain.
I admitted that fragile "Spring" have room for improvement
Seems your modified Spring work way better than the one that supplier design.
post Dec 31, 2010 - 2:45 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
exactly the same happened to mine so already removed it before i find solution frown.gif
post Dec 31, 2010 - 5:34 PM
96stgreendemon
Joined Oct 7, '09
had to fix mine again, when i popped it it would not open, ended up being the metal rod that it swivels on rusted so bad it wouldnt open, took it apart, sanded and lubed it, seems to work better.
wish my stock cap wasnt broken, i would go back to it
Lo-Fi Version Time is now: January 11th, 2025 - 1:50 PM
