> CAI make higher idle, Affect gas mileage?
post Nov 21, 2010 - 9:41 PM
mgnt232
Joined Mar 16, '09
So when starting a car in a cold environment, the rpms are higher while warming up, then they will go down to normal. But Ive noticed recently (first winter with my CAI) that the rpms will never drop to where they would normally be (a little below 1k) with the temp a little warmer outside
My intake its basically outside my car, right underneath the drivers side directional (large opening with the invaderkit). And now the temps have been falling to like 20° or below recently. I can actually feel the intake (cone splash guard) and its freezing cold even after the car is warmed up.
Im wondering if its possible that the air its sucking in is "too" cold, to where the intake temp sensor would read as if the car is still not warmed up all the way (if that makes sense). Idk if it works like that, but my rpms last year always settled down after the car is warmed up but now, its always at like 1.3k, instead of like .8k (idle). Or if there is something else I should look into.
Also could this slightly affect mileage?
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
Replies (1 - 5)
post Nov 21, 2010 - 10:29 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
mine idles a bit higher with it, plus with the header. and no it should not affect mileage.
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Nov 21, 2010 - 10:51 PM
azian_advanced
Joined Apr 18, '05
From Calgary
after the car is warmed up, your idle should drop. i noticed that while cruising, and depending on the speed you're going, the CAI gets a bit more air pressure before than the stock intake setup did but would only increased idle about 100-200 RPM. in your case though i would think that you have other issues. maybe the cold caused an air leak or something so i would start by inspecting the hoses.
and btw yes the higher idle will affect your fuel economy.
post Nov 21, 2010 - 11:20 PM
mgnt232
Joined Mar 16, '09
Yeah I thought that that much of a difference in idle rpm may be cause by something else. I looked around and saw nothing obvious, I think im going to shorten my intake to where its supposed to be for a CAI or even do a short ram to see if the idle goes down.
I cant imagine that the cold could really do any good, only bad. Especially when the temps reach below zero as they will where i live.
Just lookin for opinions smile.gif thanks guys
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
post Nov 25, 2010 - 8:56 PM
Robbie1902
Joined Oct 28, '08
From CT
Maybe try messing with the biss screw to lower the idle just a tad?
96 Celica gt 5 spd 218k intake, header, rear strutbar, new clutch...again :/
02 Saab 9-5 silver Aero 5 speed 150k w/ 80k mile engine, new clutch, k&n intake, turbos xs bov
92 sandstone grey 3000gt vr4 upgraded turbos, turboback exhaust, intake, mbc, walbro
91 black 3000gt vr4 needs work stock turbos
post Nov 25, 2010 - 9:06 PM
99GT
Joined Dec 14, '06
From MN, USA
Yes mods will lower gas mileage.
Lo-Fi Version Time is now: November 29th, 2024 - 4:28 PM
