* Please Help: Cigarette Lighter *, Cig Lighter Not Working |
Nov 23, 2010 - 6:53 PM |
Enthusiast Joined Apr 19, '10 From PA Currently Offline Reputation: 0 (0%) |
Alright. My Cig lighter has always worked, whether it was to heat the actual Cig lighter piece, or to charge a phone, plug in and power a GPS, etc. Last week I bought a little heater that was designed for cars, made by Peak. Had the heater plugged in, and it worked for about 5 minutes or so, and then off. Ever since then, the Cig lighter hasn't worked at all, no power.
Now, I checked the fuse that powers both Radio/Cig lighter.. the radio still works with fuse in, with the fuse out radio doesn't work. So with that I'm assuming it can't be the fuse because while the fuse is in it's still powering the radio. Any ideas what my next step is to get my Cig lighter working again? Need to use my GPS.. Also, I pulled out the Cig lighter and all the wires are still in place and in tact. |
Nov 23, 2010 - 8:17 PM |
Enthusiast Joined Jan 20, '08 From New York Currently Offline Reputation: 1 (100%) |
Check the manual to ensure that you have checked the proper fuse. Next check for voltage at the terminals that power the cigarette lighter. In my car the lighter was not working, it may have been corroded or an internal fault. I simply replaced it with a accessory socket from radio shack. Maybe you overheated the socket by drawing too much current causing it to fail.
Nov 23, 2010 - 8:38 PM |
I think I overheated it. If that's the case then..?
Nov 23, 2010 - 9:39 PM |
Buy a new one.
Nov 23, 2010 - 10:06 PM |
A new socket? How universal are the connections to make sure it can be wired?
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
Get a multimeter and check if there is power in the wires behind the actual unit.
Nov 24, 2010 - 1:06 AM |
Enthusiast Joined Jun 9, '09 From Saint Louis Currently Offline Reputation: 0 (0%) |
There’s a hard soldered limiter on the back of the cigarette lighter socket. When it overloads it blows and has to be replaced. You’ll see it soldered to the power line on the back of the socket when you pull it out. You can solder in a heaver limiter if you want to run higher amp accessories, but I chose to install a high load accessories socket just for accessories. Now there are much better looking ones available at auto parts stores. I put this in years ago. Takes about twenty minutes to wire up.
Nov 24, 2010 - 9:05 AM |
I see.. thanks for the info. I think what I may do for now is just try and get a replacement socket and leave it at that. Assuming I have no other issues. And I'm assuming/hoping its a matter of pulling the old one out and plugging the new one in.
Nov 24, 2010 - 9:16 PM |
I think the cigarette lighter uses standard spade correctors.
Dec 15, 2010 - 12:12 AM |
Enthusiast Joined Dec 14, '10 From Lansing MI Currently Offline Reputation: 1 (100%) |
the same thing happened to me before but it was just the fuse
Dec 15, 2010 - 1:15 PM |
Lo-Fi Version | Time is now: January 10th, 2025 - 7:39 PM |
