7A-FE Engine |
7A-FE Engine |
Dec 9, 2010 - 3:42 PM |
Enthusiast Joined Dec 9, '10 From SC Currently Offline Reputation: 0 (0%) |
Hey guys,
I'm new here and wanted to get something straight. Are the 7A-FE motors from 90's Corolla the same as the 7A-FE in the Celica's? I have a 97' ST Celica that threw a rod bearing and I'm looking for a replacement engine. Would it be safer to buy a OBDII 7A-FE from another Celica or would a 94-95 Corolla motor do? If a Corolla motor will do, what are some of the things I would need to use from the Celica 7A-FE to work with the 7A-FE in the Corolla motor? Any info would be appreciate. Thanks! |
Dec 9, 2010 - 3:48 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
a 94/95 Corolla motor would be too much trouble since it's OBDI
-------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Dec 9, 2010 - 4:00 PM |
a 94/95 Corolla motor would be too much trouble since it's OBDI Okay, when did the Corolla's go to OBDII? 97? And would a 7A-FE out of that year be easier to swap into the Celica? On another note, I can't seem to find any 7A-FE motors from 97's, I've only found a few out of 96's, are they the same as 97's 7A-FE's aka OBDII? This post has been edited by SCPOW: Dec 9, 2010 - 4:07 PM |
Dec 9, 2010 - 4:21 PM |
Okay, when did the Corolla's go to OBDII? 97? And would a 7A-FE out of that year be easier to swap into the Celica? On another note, I can't seem to find any 7A-FE motors from 97's, I've only found a few out of 96's, are they the same as 97's 7A-FE's aka OBDII? Yeah, anything '96 and after is OBDII. That's when the change was made. and the Corolla with the 7A in America was the AE102, from 93-97 -------------------- taking too long to mod since '09
Dec 9, 2010 - 6:40 PM |
Okay, when did the Corolla's go to OBDII? 97? And would a 7A-FE out of that year be easier to swap into the Celica? On another note, I can't seem to find any 7A-FE motors from 97's, I've only found a few out of 96's, are they the same as 97's 7A-FE's aka OBDII? Yeah, anything '96 and after is OBDII. That's when the change was made. and the Corolla with the 7A in America was the AE102, from 93-97 So a 96' 7A-FE out of a Corolla or a Celica would simply drop right back into my 97' Celica? Anyone with any suggestions? |
Dec 10, 2010 - 6:22 PM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
The OBD1 would also work with minor mods basically you will swap the Intake manifold from yours to the new engine
Dec 10, 2010 - 6:30 PM |
Enthusiast Joined Oct 7, '09 Currently Offline Reputation: 8 (65%) |
check out my thread, its in the exterior styling portion of the site, i went through the same thing basically
i am putting in a 94 celica st engine into a 97 shell.. its almost done, and i put up all the problems and changes i had to go through... good luck either way! -------------------- NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold 1997 Celica ST- swapped and sold 2004 Ford explorer xlt 4x4- totaled 1997 Celica Convertible GT- Going Topless (; (18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi ( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 ) |
Dec 10, 2010 - 11:53 PM |
there is bad info here, sure the year went to ODBII but that doesnt matter. the OP threw a rod, thats the bottem end! any and i mean ANY 7A bottom end will work just fine for you. all you ahve to do is put your head, manifolds, and accessories on it. sometimes you might get away with long block swapping just using your electronics.
Get out of the box, there is always an option -------------------- 2001 Celica GT-S Turbo
Dec 11, 2010 - 1:30 AM |
I have no knowledge of putting a motor together so that's why I choose to just buy another 7A-FE motor and drop it back in.
Question here is which motor would be easiest to drop in? I can't seem to find any 97' 7A-FE, is a 96' the same? And 96st, what other minor mods would I need to make a older OBDI motor work? |
Dec 11, 2010 - 9:39 AM |
wow. lots of misinformation here.
you can use just about any 7afe you want, keeping these things in mind. if your car is 96+, like yours is, and you use a replacement out of an earlier year, you will have to use the following parts off your current motor. intake (with throttle body) and exhuast manifolds coolant waterneck crank position sensor, oil pump housing, and crank pully with intergrated trigger wheel for the crank position sensor possibly fuel rail and injectors (but thats more a 5sfe thing) harness and ecu thats the short list. basicly anything on the motor that has a sensor, your gonna wanna check against what you have, and make sure they are the same. if not, use the part off the old motor. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Dec 11, 2010 - 11:54 PM |
^^^ exactly, usually when you buy a used engine, you only get the longblock, no manifolds. so you will have to just transfer your stuff over. its not assembling the engine, just the sensors and manifolds.
Dec 13, 2010 - 6:18 PM |
wow. lots of misinformation here. you can use just about any 7afe you want, keeping these things in mind. if your car is 96+, like yours is, and you use a replacement out of an earlier year, you will have to use the following parts off your current motor. intake (with throttle body) and exhuast manifolds coolant waterneck crank position sensor, oil pump housing, and crank pully with intergrated trigger wheel for the crank position sensor possibly fuel rail and injectors (but thats more a 5sfe thing) harness and ecu thats the short list. basicly anything on the motor that has a sensor, your gonna wanna check against what you have, and make sure they are the same. if not, use the part off the old motor. That sounds like a lot to swap over. I'm a Nissan guy and when I dropped a earlier motor year 93' into my 97' chassis, I swapped distributor and intake manifold and ta da that was it. Is all that stuff listed above just SOME of the items I have to swap over? That sounds like a lot of stuff. =\ |
Dec 14, 2010 - 12:51 AM |
not sure how you got away with that since you put an ODBI engine in an ODBII car
Dec 14, 2010 - 3:44 AM |
not sure how you got away with that since you put an ODBI engine in an ODBII car Does anyone have a list of what is all needed from an OBDII engine to make a OBDI engine work in a OBDII chassis? Someone said I should search and trust me, I searched before I joined the forums but I had no luck. |
Dec 14, 2010 - 1:48 PM |
Pretty much, you just have to take everything off your '97 block, then put it all on the new block you get.
Apr 4, 2011 - 12:53 PM |
Enthusiast Joined Apr 1, '11 Currently Offline Reputation: 0 (0%) |
I'm looking to do a swap. The donor car being a 1996 Corolla 7afe. The car it will be going into is a 1996 Celica that already has the same 7afe. I haven't looked too much at the coroll but i did notice the map sensor is a bit smaller and different, other than that things look the same. I get work release from jail everyday so i'm lookin to get this all done in 1-2 days. I've done a few engine swaps and builds so i'm wondering what problems i'm going to have that anyone knows of before i start at it? I know i could play around and take my time and read an fsm on both but kinda short on time. Thanks
Apr 4, 2011 - 3:21 PM |
Enthusiast Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
I'm looking to do a swap. The donor car being a 1996 Corolla 7afe. The car it will be going into is a 1996 Celica that already has the same 7afe. I haven't looked too much at the coroll but i did notice the map sensor is a bit smaller and different, other than that things look the same. I get work release from jail everyday so i'm lookin to get this all done in 1-2 days. I've done a few engine swaps and builds so i'm wondering what problems i'm going to have that anyone knows of before i start at it? I know i could play around and take my time and read an fsm on both but kinda short on time. Thanks Did they teach you to read as well? Cause...yea..scroll up. |
Apr 4, 2011 - 3:46 PM |
Did they teach you to read as well? Cause...yea..scroll up. Aww don't be so harsh I laughed, though -------------------- taking too long to mod since '09
Apr 4, 2011 - 3:49 PM |
Did they teach you to read as well? Cause...yea..scroll up. Aww don't be so harsh I laughed, though Lol, i'm usally not. Tend to be quite peaceful. Dudes name is "Vagina" though, then asked the same damn question as the original post. Hard to respond serious to that =P |
Apr 4, 2011 - 5:12 PM |
Read? What's that? And where in the earlier posts does is state the complications, if any, of doing an obd II 7afe into another obd II 7afe? Please enlighten me And going from the same chassis is an obvious given that everything should work (depending on year), But i'm looking at an engine coming out of a corolla and going into a celica. Just in case some of you forgot or can't read earlier posts
Edit. So to ask question into simple terms... What differences are there between the obd II 7afe in a 1996 toyota corolla vs. an obd II 7afe in a 1996 toyota celica? I noticed the map sensor is different. What problems would I have with that? Can i just use my map sensor? I think I can but I know there someone on here that's done this a time or two that has some pretty useful info that'll help alot. Thanks. This post has been edited by vagina: Apr 4, 2011 - 5:18 PM |
Lo-Fi Version | Time is now: November 27th, 2024 - 11:37 AM |
