> ST205 o2 sensor part number? help!
post Feb 9, 2011 - 11:02 PM
TEAMFaint
Joined Nov 4, '06
From Medicine Hat, AB
Anyone help a guy out?
Overhauling the 205 maintenance wise to try and convince myself to keep the thing.
also need part number for the water level sensor for the w/a intercooler.
current project: looking :(
Replies (1 - 6)
post Feb 9, 2011 - 11:35 PM
Rusty
Joined Nov 5, '07
From New Zealand
89465 SENSOR, OXYGEN
89465-29725 ST205 1 $224.39
89256 SENSOR, LEVEL WARNING
89256-20010 ST205 1 $121.05
post Feb 9, 2011 - 11:43 PM
TEAMFaint
Joined Nov 4, '06
& of course, now to find one...
post Feb 10, 2011 - 4:56 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
are u getting code 54? i just cut the wires and joined them together, it's a pain in the ass that water level sensor.
Mike W
269awhp / 273ft-lbs
post Feb 10, 2011 - 10:51 AM
TEAMFaint
Joined Nov 4, '06
QUOTE (delusionz @ Feb 10, 2011 - 4:56 AM) *
Yes I am getting code 54. Can you help explain what you mean by cutting the wires and joining them together?
I have checked my pump. Works fine. Fluid is topped up. I wanna get rid of this code.
I know there is a black and red wire off the sensor. How do I "join these" to the other end of the plug.
Do you mean cut the black and red wire and simply splice them together and then attach it to the other end of the plug in the engine bay?
post Feb 10, 2011 - 11:12 AM
QUOTE (TEAMFaint @ Feb 10, 2011 - 10:51 AM) *
for the o2 sensor you can order one for a 93 alltrac, they are the same.
for the level sensor, just unplug it, cut the plug off the harness side, and bridge the 2 wires together.
then you can remove the little boot covering the wiring going to the sensor itself, and snip the wires off, and reinstall the little boot for a clean look.
post Feb 10, 2011 - 12:52 PM
TEAMFaint
Joined Nov 4, '06
Thanks for the info my friend, will be tackling this today!
This post has been edited by TEAMFaint: Feb 10, 2011 - 12:54 PM
Lo-Fi Version Time is now: February 21st, 2025 - 12:09 PM
