> 5fse Engine Running loud
post Feb 24, 2011 - 6:56 PM
kamax
Joined Apr 29, '03
From lynn,ma
Hey I was wondering what's the best way to diagnosis why my engine is making the noise that it makes. It's really loud like something is leaking. It's loud when idle and louder when revved. What's the common cause of this? I'll post video of the sound when I get the chance.
Thanks.
View My Video
for video
when idle it's loud... is it exhaust leak or something else? what do you guys think
This post has been edited by kamax: Mar 9, 2011 - 6:08 AM
Replies (1 - 12)
post Feb 24, 2011 - 7:54 PM
is it a knocking sound, you might have spun a bearing.
post Feb 24, 2011 - 9:00 PM
kamax
Joined Apr 29, '03
From lynn,ma
it's more of a loud muffler loose sound, but kinda guggling sounds kinda after the rev is let go?
post Feb 24, 2011 - 9:26 PM
u prob have an exhaust leak
post Feb 24, 2011 - 11:42 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (Smaay @ Feb 24, 2011 - 10:26 PM) *
If the little hose from the intake to the valve cover(like a large vacume hose) melts as my cheap hose did) or leaks it will sound like the car is going to bloow up.
This post has been edited by xrav22: Feb 24, 2011 - 11:43 PM
post Mar 9, 2011 - 6:09 AM
kamax
Joined Apr 29, '03
From lynn,ma
bamp
post Mar 9, 2011 - 3:05 PM
97Supra
Joined Feb 8, '08
From NJ
The hissing sound is your idle air control valve, the clunk or girgle that is barely audible upon deceleration could be many things, the sound quality is really terrible. Could be a misfire, could be an exhaust leak causing popping sounds, could be worn exhaust hanger allowing the exhaust to bang into the underside of the vehicle when torque is applied.
If you want to find an exhaust leak, when the car is cool / cold start it up, and cover your hand with a rag or towell and cover the tail pipe (with force don't let air escape for a few seconds) if there is a breach anywhere you will hear exhaust escaping from it. visibly, you'll be able to see soot around where the hole / crack in the exhaust is usually.
Do not try this when the car has been running for a while or hot, you will get burned. Please exercise caution.
This post has been edited by 97Supra: Mar 9, 2011 - 3:18 PM
post Mar 9, 2011 - 3:31 PM
kamax
Joined Apr 29, '03
From lynn,ma
What I am more worry about is the loud ass idle. Sounds like a freaken lawn mower lol. Thanks I'll try that covering the exhaust up when the engine cool down a bit. You think running seafoam in might have cause the problem? and you think throwing seafoam in might help identify where the leak is coming from since you know... seafoam make hella smoke lol
post Mar 28, 2011 - 7:15 PM
kamax
Joined Apr 29, '03
From lynn,ma
well, i found the exact problem today (weather permitted)
turn out there's a hole in my exhaust lol. is this the cat converter?
and will this fit to replace it
http://shop.advanceautoparts.com/webapp/wc..._1566516677____
yeah the pipe is the one from down from the exhuast manifold /engine area. front of the car between the front wheels
This post has been edited by kamax: Mar 28, 2011 - 7:16 PM
post Mar 28, 2011 - 7:19 PM
mkernz22
Joined May 10, '10
From MA
no that's no the CAT at all haha
it's like a flex / resonator part on the pipe
post Mar 28, 2011 - 7:27 PM
kamax
Joined Apr 29, '03
From lynn,ma
QUOTE (mkernz22 @ Mar 28, 2011 - 5:19 PM) *
yeah i figure that much after looking around a bit =p , but onto the next question... will that replacement work? ^_^
cat is in the back i am guessing, before the muffler.
post Mar 28, 2011 - 7:33 PM
mkernz22
Joined May 10, '10
From MA
the cat is actually right in the middle of the car, but i have no clue what you should replace that with
post Mar 28, 2011 - 7:44 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
It's a flexi joint. The exhaust is held in pretty solid with the factory exhaust hangers, when the engine is revved the torque moves the engine back and forth, the flexi is just there to absorb this movement so that you dont pull the exhaust manifold nuts off when it's revved.
just go to an exhaust shop and they will cut it out and weld in a new one, it shouldn't be very expensive
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: January 9th, 2025 - 9:54 PM
