> Ticking noise, Coming from valve cover area
post Mar 8, 2011 - 7:02 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Doesn't this usually mean that a valve adjustment is needed? Because I got my valves adjusted not more than 12k miles ago... is it already time again?
June '12 COTM
'95 AT200
Replies (1 - 10)
post Mar 8, 2011 - 7:37 PM
Injectors, I'm willing to bet.
As in, 7A fuel injectors are noisy.
post Mar 8, 2011 - 7:38 PM
HectortheRican
Joined Dec 26, '09
It's seemed louder than usual.
June '12 COTM
'95 AT200
post Mar 8, 2011 - 8:34 PM
That's what she said!
post Mar 8, 2011 - 10:40 PM
Lone_Wolf
Joined Apr 22, '09
From Work
Who did the adjustment for you ?? It could also be a sticky lifter from sludge build up, but if the ticking is that bad take the valve cover off and recheck the clearance.
**If you can read this you are too close**
post Mar 9, 2011 - 9:54 AM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
mine does it too..... i just turn up the radio lol
2001 Solar yellow Lexus IS300
post Mar 9, 2011 - 10:58 AM
HectortheRican
Joined Dec 26, '09
QUOTE (96stgreendemon @ Mar 9, 2011 - 7:54 AM) *
Lol Kyle. Mine's not that bad that I hear it in the cabin. I popped my hood while the motor was running and heard it.
June '12 COTM
'95 AT200
post Mar 9, 2011 - 7:32 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
7a has REALLY noisy injectors, sounds like a rapid and sharp clicking noise. valve tap is deeper more "mechanical" sounding.
post Mar 10, 2011 - 10:27 AM
6and7
Joined Feb 27, '11
From Houston
does yours ticking start at around 3000 rpms? cause mine does and i cant figure out what it its
post Mar 10, 2011 - 11:01 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
exhaust leak? That'll make a ticking sound.
Timing/accessory belt loose? That'll make a ticking sound
**** Photobucket
post Mar 10, 2011 - 11:24 AM
HectortheRican
Joined Dec 26, '09
QUOTE (6and7 @ Mar 10, 2011 - 8:27 AM) *
Idling. It's probably the injectors, or a sticky lifter someone had said earlier.
QUOTE (95CelicaST @ Mar 10, 2011 - 9:01 AM) *
No, the exhaust is fine. The timing belt was replaced less than 2k miles ago and the other belts should be fine as well, it hasn't even been 12k for those.
June '12 COTM
'95 AT200
Lo-Fi Version Time is now: February 17th, 2025 - 8:36 PM
