> knocking noise while shifting?
post Mar 13, 2011 - 2:51 PM
Ted95
Joined Mar 8, '09
From Westport, MA
hey guys, i need some help on something. my car makes this knock noise after i ingage 1st, 2nd and 3rd gear and also when i let off the gas.
it sounds like somethin moves when the engine makes its natural movement or when the car jerks a little. im not really sure what it is. i havent put it on a lift yet but im going to try this week. this started after i replaced my clutch in july, it does happen everytime but enough to make me want to look into it and it seems to be a little louder then b4.
im not sure if it is a mount or maybe and axel being jerked i really dont kno and would appriciate any advice if anyone has had this problem in the past or might kno what it is.
st205 powered ss3 coupe
Replies (1 - 14)
post Mar 13, 2011 - 3:46 PM
zfjohnson07
Joined Apr 11, '09
pop the hood and look! theres 4 motor mounts one in the front back and sides, just examine it
post Mar 13, 2011 - 5:11 PM
chacha
Joined Dec 29, '05
From So-Cal
video is better than description
post Mar 13, 2011 - 5:53 PM
mkernz22
Joined May 10, '10
From MA
could it be something with the clutch itself? cause that almost seems like the most logical thing since you said it started right after you replaced your clutch
post Mar 13, 2011 - 7:25 PM
Ted95
Joined Mar 8, '09
From Westport, MA
im not really sure. because when we dropped the tranny, one of the axles wouldnt come out thats why i say maybee the axle but im not sure. ill check the mounts next chance i get, the three that are visible look fine, the 4th i cant see, could be that one.
i really dont think its the clutch bc it does work well, (considerin the flywheel wasnt resurfaced lol) i guess i could try and get a video but i doubt you would hear anything bc it prob wont pick up the sound.
it sounds like something is moving so it probably is the mount, ill look Tuesday.
post Mar 13, 2011 - 8:25 PM
its not clutch related. chances are its a motor mount that has gone out and the engine is rocking back and forth when you get onn and off the gas
post Mar 13, 2011 - 9:27 PM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (Smaay @ Mar 13, 2011 - 9:25 PM) *
ya thats sounds like a very good possibility. i just wanted to ask around and see if anyone has had this issue b4 and might have an answer.
ill take a look at it this week and see what it is. thanks guys
post Mar 13, 2011 - 10:56 PM
mak5603
Joined Oct 20, '08
I had the same problem a year or so ago. My rear mount bolt was just plain missing...and the mounts were in pretty bad shape. I just slapped some Kirkosaurus mount inserts in the front and rear mount which was really easy and it solved the problem and then some. biggrin.gif
So yeah, I would say it is more than likely your rear motor mount.
2014 Toyota Rav4 XLE
post Mar 14, 2011 - 7:29 AM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (mak5603 @ Mar 13, 2011 - 11:56 PM) *
Alright cool man thanks.
Hey how much of a difference did those inserts make? Do u have a lot of vibration with just the front and rear inserts?
post Mar 14, 2011 - 8:14 AM
Chances are it's the rear mount.
Inserts make a huge difference.
post Mar 14, 2011 - 10:22 AM
csscza
Joined Apr 28, '10
From Ft Worth
inseerts?? what inserts?
post Mar 14, 2011 - 11:59 AM
mak5603
Joined Oct 20, '08
Kirkosaurus motor mount inserts. Yeah they make a great difference, and yeah there is some vibration.
post Mar 14, 2011 - 12:01 PM
blu94gt
Joined Mar 23, '05
From Kansas City
+1 for mounts. Either are bad or just didn't get torqued down properly when the clutch was installed.
1999 Celica GT
post Mar 14, 2011 - 10:44 PM
Ted95
Joined Mar 8, '09
From Westport, MA
ya im lookin into the inserts now. and idk ill check the mount tuesday.
post Mar 17, 2011 - 3:54 PM
Ted95
Joined Mar 8, '09
From Westport, MA
yep rear mount looks a lil shakey, ill get the inserts and fix it when the new motor goes in.
Lo-Fi Version Time is now: November 30th, 2024 - 5:41 AM
