> 4AGE 20v wont idle right or go over 60mph!, I did a engin swap from a 7afe to 4age and it runs poor!
post Mar 30, 2011 - 11:00 PM
trd_fun
Joined Dec 29, '10
From san antonio
After doing the swap the car runs but it wont idle right. it idles at 800rpms and it wont go faster then 60mph.
I been trying to get this fixed right for 2 months now. I changed the ECU and i also changed the MAF thinking it would be these two things but it didnt work. When i put the new ECU in it ran right for like 4 or 5 days then it went back to the same problem. It feels like its holding back power and it smells like heavy gas fumes all the time.
Can any one help with some ideas to what it could be!??
Thanks guys.
Replies (1 - 6)
post Mar 31, 2011 - 1:06 AM
zonz540
Joined Jul 3, '09
From UT
O2 sensors?
Try Nik, he knows a good amount about the 4A motor.
post Apr 2, 2011 - 2:59 PM
trd_fun
Joined Dec 29, '10
From san antonio
QUOTE (zonz540 @ Mar 31, 2011 - 1:06 AM) *
O2 sensors?
Is Nik on 6gc??
post Apr 2, 2011 - 3:24 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
why don't you try club 4ag!! or something like that
http://www.club4ag.com/
post Apr 3, 2011 - 6:05 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
are you using the 20v ignitor? Also double check all of the vacuum lines and make sure they are connected in the right locations. Also, check for check engine codes to see what you come up with and post them as soon as you can.
This post has been edited by netrata: Apr 3, 2011 - 6:06 PM
post May 1, 2011 - 8:56 PM
trd_fun
Joined Dec 29, '10
From san antonio
QUOTE (netrata @ Apr 3, 2011 - 6:05 PM) *
Its the ecu.I open it up and it was burned in one spot on both ecu's! I think where its burned out at controls the VVT.
post May 2, 2011 - 4:45 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I had that on 2 different ecus, it didn't seem to make any difference. Cold starts where the worst, I sit their and crank and crank for a good 2 mins b4 it fired up. Vvt works, but its the idle control valve that the ecu can't control. MOre than likely you wired up something that wasn't supposed to be hooked up. Switched to MS2, waiting to finsh the install after 2 years lol.
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 9th, 2025 - 6:30 PM
