Enthusiast Joined Jan 1, '10 From Florida Currently Offline Reputation: 0 (0%) ![]() |
so the car turns on and goes into gear smoothly with or without the clutch. but the problem is the car wont move.. any input?
Enthusiast ![]() ![]() Joined May 30, '05 From MN Currently Offline Reputation: 8 (100%) ![]() |
Car should go into gear only when you depress the clutch while it is on/running. Sounds like your clutch is out. Hopes that helps.
-------------------- 3sgteing.
..burns twice as bright, lasts half as long. "The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction." -Allen Ginsberg- |
Car should go into gear only when you depress the clutch while it is on/running. Sounds like your clutch is out. Hopes that helps. dont think its the clutch bro. i just changed it out recently but im pretty sure its either has to do with the axle or the cv joint . i can see it underneath the car i just wasnt too sure so i was looking to get some input |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) ![]() |
Car should go into gear only when you depress the clutch while it is on/running. Sounds like your clutch is out. Hopes that helps. dont think its the clutch bro. i just changed it out recently but im pretty sure its either has to do with the axle or the cv joint . i can see it underneath the car i just wasnt too sure so i was looking to get some input how can you get the car in gear without putting the clutch in? maybe you forgot to hook up the shift linkage. |
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) ![]() |
not the axle mine was cracked and still moved, drove it 1000 miles like that. so guess again
![]() Enthusiast ![]() ![]() ![]() Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) ![]() |
either you shift cables are not connected or your clutch is permanently engaged...it should not go into gear without the pedal pushed
-------------------- ST205 Crew represent
![]() Challenge Accepted |
Enthusiast Joined Mar 20, '11 From Milwaukee Currently Offline Reputation: 0 (0%) ![]() |
Yea it's your clutch. Happened to my buddies Cobalt. His was burnt up
Yea it's your clutch. Happened to my buddies Cobalt. His was burnt up hmm idk how it could be the clutch i JUST replaced it not too long ago. well it was raining and i didnt get to really get underneath and look im gonna take a look tomorrow and find out whats what ![]() |
Enthusiast ![]() ![]() ![]() ![]() Joined Sep 27, '10 From pittsburgh Currently Offline Reputation: 4 (100%) ![]() |
Could have been installed wrong, faulty clutch, there could be many reasons.
The pivot point on your clutch fork could have broke, regardless I doubt it's an axle. Could be but I doubt it, the car does have an open diff so if the axles broke you wont move but there would probably be some resistance going into gear without the clutch. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD -10 F150 Always buying stock wheels... PM me if interested in selling. |
Could have been installed wrong, faulty clutch, there could be many reasons. The pivot point on your clutch fork could have broke, regardless I doubt it's an axle. Could be but I doubt it, the car does have an open diff so if the axles broke you wont move but there would probably be some resistance going into gear without the clutch. well i got underneath today and from what i saw the front driverside axle is broken.gonna get it swapped out and hopefully back on the road soon. i appreciate everyones input and hopefully it really isnt the clutch ![]() |
Could have been installed wrong, faulty clutch, there could be many reasons. The pivot point on your clutch fork could have broke, regardless I doubt it's an axle. Could be but I doubt it, the car does have an open diff so if the axles broke you wont move but there would probably be some resistance going into gear without the clutch. well i got underneath today and from what i saw the front driverside axle is broken.gonna get it swapped out and hopefully back on the road soon. i appreciate everyones input and hopefully it really isnt the clutch ![]() You can check, jack the car up. Have someone put it in first gear, if the broke axles is spinning right by the transmission its just the axles and not the clutch. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
Could have been installed wrong, faulty clutch, there could be many reasons. The pivot point on your clutch fork could have broke, regardless I doubt it's an axle. Could be but I doubt it, the car does have an open diff so if the axles broke you wont move but there would probably be some resistance going into gear without the clutch. well i got underneath today and from what i saw the front driverside axle is broken.gonna get it swapped out and hopefully back on the road soon. i appreciate everyones input and hopefully it really isnt the clutch ![]() You can check, jack the car up. Have someone put it in first gear, if the broke axles is spinning right by the transmission its just the axles and not the clutch. yea thats exactly what it was |
Lo-Fi Version | Time is now: February 19th, 2025 - 7:03 PM |
