> Drivers side cv axle, need an opinion
post Apr 5, 2011 - 8:35 PM
Kharma
Joined May 20, '10
From DFW
Last time we tried doing the drivers side axle we thought it was all the way in and wasn't and ended up breaking the tip off. This time we would like to get another opinion on whether or not this looks like it is in all the way.
Will appreciate all the input given. THanks
Replies (1 - 7)
post Apr 5, 2011 - 9:17 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
Take a rubber mallet and tap the axle in. When it is in all the way you'll hear difference from the sound being not in all the way and being in all the way. Plus the axle won't go any farther.
2nd Gen 3s-gte.... It lives!
97celiman
post Apr 5, 2011 - 9:34 PM
Kharma
Joined May 20, '10
From DFW
well we took a crowbar and push on the ridges on the axle(the big metal peice) and it wouldn't go in but idk if its in or not. We will try the hammer tomorrow
post Apr 5, 2011 - 9:45 PM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
I had similar issue recently. To me it looks its not all the way in. I thought it was and when I poured transmission fluid it started leaking. I put a piece of wood on it and hit it the wood with hammer and it slided all the way in.
post Apr 6, 2011 - 7:44 AM
HIT IT YOU PANSY! or atleast thats what my Boss yells...
post Apr 6, 2011 - 1:46 PM
Kharma
Joined May 20, '10
From DFW
So when i hit it it just kinda abosorbs the blow... SHould i just hit it harder?
post Apr 6, 2011 - 3:40 PM
Hanyo
Joined Aug 16, '03
From Bay area
the way i do it is:
alight the axle so its as straight as you can get it. Then hit the side where it connects to the steering knuckle with a rubber mallet. If that doesn't try reseating the axle.
post Apr 6, 2011 - 5:40 PM
Kharma
Joined May 20, '10
From DFW
Well we got it with a crowbar. Unfortunately while taking out the transmission we bent the plate going around the outside of the tranny and now the flywheel is rubbing it kindasad.gif
Lo-Fi Version Time is now: February 20th, 2025 - 1:38 AM
