![]() Enthusiast ![]() Joined Jun 1, '08 From STL Currently Offline Reputation: 0 (0%) ![]() |
So far this is what I've available:
ST202/4 Tranny Mount 12372-74451 (S54) $74.17 ST202/4 Rear Mount 12371-74411 (S54) $49.03 ST202/4 Rear Bracket 12321-74321 (S54) $34.32 ST202/4 Timing Side Bracket #1 12315-74130 $77.66 ST202/4 Timing Side Bracket #1 Bolts (3) 90119-10599 $3.72 ST202/4 Timing Side Bracket #2 12316-74070 $31.74 ST202/4 Timing Side Stabilizer 12381-74020 $9.49 I have a used ST202/4/5 PS High Pressure Hose 44410-2B030. Perfect condition. I'm open to offers. I have a used ST202/5 Speedometer Gear/Sensor for E Series transmissions 83181-12050. Perfect condition. I'm open to offers. For those of you running 2nd or 3rd Gen 3SGTEs: SW20 MR2 TRD Metal Head Gasket PTR04-17910-01 (11115-SW201) $84.40 SW20 93-97 MR2 TRD Plug Wires PTR04-17920-02 (19051-ST811) (should work for all 2nd Gen 3SGTEs as well, CMIIR) $136.05 And for those of you wanting to squeeze a bit more power out of your 5SFE: ST202 3SGE OEM Exhaust Manifold (4-2, should work for all you 5SFE folks) $65 PM here or on Ctech if you're interested in any of this stuff. Cheers, RedRkt01 This post has been edited by RedRkt01: Jul 28, 2011 - 1:36 PM |
Bump.
Bump!
Bump!
'nother bump!
New month bump.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) ![]() |
is it a definite fit on the 5sfe with the header?
Enthusiast ![]() Joined Feb 6, '11 From TORRANCE Currently Offline Reputation: 0 (0%) ![]() |
I have a 95 celica gt 5sfe will the 3sge manifold fit and is it a direct bolt on?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) ![]() |
Redrkt01, are you still able to get the poly-urethane pushings you used to sell on celicatech?
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Through Superpro yes.....not through Poland.
I have a 95 celica gt 5sfe will the 3sge manifold fit and is it a direct bolt on? I need to find a 5S gasket to see if it matches up......I believe I've done this before so I think it works, but I have to make sure as I'm not positive. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) ![]() |
Pm'd about plug wires
ttt
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) ![]() |
is the speedo gear the one on the diff or the sensor?
is the speedo gear the one on the diff or the sensor? Both....sort of. It is the sensor which takes its reading from a gear on the end of it. That gear on the end mates up to a plastic ring gear in the diff housing. A picture of what it is can be seen in this ebay listing: http://cgi.ebay.com/ebaymotors/93-95-SW20-...=item2565eba9a8 You can also search the part number that I listed. This post has been edited by RedRkt01: Jul 28, 2011 - 1:29 PM |
So the whole speed sensor assy?
I'm not really sure what you're asking here. Between the the picture and the part number I think you should be able to know if what I'm selling is indeed what you want. What I'm selling is exactly what's in the ebay listing. If that is what you need, then that is what I can provide you with.
Wanted to be perfectly clear. I'm on a phone so the pic was small.
Ah, I see. I needed the one on the diff. Thanks!
Lo-Fi Version | Time is now: February 23rd, 2025 - 12:10 PM |
