> using stock 5sfe MAP sensor on a 3sgte?
post May 24, 2011 - 6:12 PM
match220
Joined May 13, '06
From Kaimuki, HI
I'm probably going to change out my map sensor but I'm just wondering how many bars or psi it can actually handle when the engine is turbo'd. If it works on the stock genIII turbo then I'll probably keep it. What about the stock supra map sensor? anyone know how many bars/psi it can handle?
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
Replies (1 - 7)
post May 24, 2011 - 6:16 PM
Johnnyny
Joined Apr 28, '09
From York pa
just wait and buy a map sensor
post May 25, 2011 - 9:13 AM
the 5S MAP sensor will confuse the 3S-GTE ECU and the engien will not run properly. just do it right.
post May 25, 2011 - 12:04 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (Smaay @ May 25, 2011 - 4:13 AM) *
I'm running an Autronic SM4, so I can use whatever sensor I want.
-Jay
post May 25, 2011 - 3:11 PM
azian_advanced
Joined Apr 18, '05
From Calgary
just fyi...
so yea, will not work.
post May 25, 2011 - 3:14 PM
azian_advanced
Joined Apr 18, '05
From Calgary
double post
This post has been edited by azian_advanced: May 25, 2011 - 3:15 PM
post May 25, 2011 - 5:25 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
so it looks like you will be able to tune in about 6 or 7 pounds? tho the tune cost more enough to make it worth doing it once and doing it right tho?
Mike W
269awhp / 273ft-lbs
post May 25, 2011 - 10:03 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (delusionz @ May 25, 2011 - 12:25 PM) *
I can tune it, I went through tuning school and I've played around with aftermarket EMS's before but it's not my job, I'm just a regular mechanic so I use the autronic forums for help a lot. I can street tune it with the streettuner software or run the autotune function of the autronic and then tweak that. It's not that bad, costs me nothing smile.gif
-Jay
Lo-Fi Version Time is now: January 10th, 2025 - 3:14 AM
