> new engine mount replacements
post Jun 2, 2011 - 12:03 AM
vile_v
Joined Jun 16, '07
From Vancouver, Canada
Replies (1 - 3)
post Jun 2, 2011 - 1:19 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Do those press in where you burn out the stock rubbers? or do you weld to that for custom mounts
Mike W
269awhp / 273ft-lbs
post Jun 2, 2011 - 1:37 PM
delusionz
Joined Feb 11, '08
I just took mine all 4 to a suspension shop where they either made a mould (or already had a mould) of the stock mounts, then burnt out the rubber and filled the mounts with polyurethane liquid which took 3 days to set, i ended up with 4 polyurethane bushed oem mounts, the reason they have the mould is so they can put the stock flex gaps
i was told to do all 4 because the extra vibrations would wear out the rubber ones quicker
This post has been edited by delusionz: Jun 2, 2011 - 1:43 PM
Mike W
269awhp / 273ft-lbs
post Jun 5, 2011 - 12:29 AM
vile_v
Joined Jun 16, '07
QUOTE (delusionz @ Jun 2, 2011 - 11:37 AM) *
yes these are the very same kind. A big pain in the * to put them in. How were they able to make a stiffer hydraulic one and the driver side one?
Lo-Fi Version Time is now: January 15th, 2025 - 5:25 AM
