> FMIC + Berk DP installed, now overboost *SOLVED*
post Jun 18, 2011 - 11:49 PM
Domspun
Joined Oct 15, '10
From Brossard
I installed my FMIC and Berk DP and now it overboost!! Before, I couldn't boost over 14 PSI and now even with my MBC completly unscrewed, I hit the fuel cut all the time very fast! Seems like my actuator doesn't open!?
This post has been edited by Domspun: Jun 21, 2011 - 6:21 PM
Replies (1 - 7)
post Jun 19, 2011 - 6:03 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
How big is your exhaust?
Mike W
269awhp / 273ft-lbs
post Jun 19, 2011 - 6:08 AM
delusionz
Joined Feb 11, '08
I think you're almost garanteed to overboost once you change the intake and exhaust, unfortunately theres not much port work you can do in a twin scroll turbo, now if you want to keep your mods you also have to get a new manifold and external wastegate.. while your at it you may aswell get a better turbo and ditch that toyota piece of crap.
Mike W
269awhp / 273ft-lbs
post Jun 19, 2011 - 6:57 AM
ST205WRC
Joined Dec 30, '10
From amarillo texas
i think we could use a mod list before jumping into telling him to get a new turbo setup.
post Jun 19, 2011 - 7:10 PM
Domspun
Joined Oct 15, '10
From Brossard
I'll list my intake/exhaust mods:
- Obviously Berk DP
- DP to back 3'' Fujitsubo exhaust
- Samco intake hose
- Apex'i Air intake
- Apex'i BOV
- MBC with the mods to remove the OEM boost control
- Stock ECU
- FMIC, 2.5'' piping
- Wiring mod to remove Code 54 and bridge the intercooler level sensor.
Car runs great, should I be able to move the actuator by hand? What if I plug the hose directly in the actuator from the compressor housing?
post Jun 19, 2011 - 7:17 PM
delusionz
Joined Feb 11, '08
nah it shouldnt move by hand,
theres a couple ways to keep your currrent setup,
the easy way would be to put a 2.25" restrictor in your exhaust which would defeat the purpose of removing the cat and the full 3" system,
or a standalone ecu and just tune it and run it full time at over 18psi,
or external wastegate which means cutting up your new downpipe and your manifold,
or a fuel cut defender with water injection (but getting the setup right this way is almost as costly as the ecu)
Mike W
269awhp / 273ft-lbs
post Jun 19, 2011 - 8:44 PM
Domspun
Joined Oct 15, '10
From Brossard
I have a Greddy E-manage Blue that I was planning to install. Could it solve my problem?
Did anybody installed a external wastegate on a WRC manifold? I won't cut my DP, if I have to put a external wastegate, I'll just put a pipe on it and exit under the car. It's a track car after all!
post Jun 21, 2011 - 6:22 PM
Domspun
Joined Oct 15, '10
From Brossard
Problem solved! My MBC was busted, spring was bent and a ball bearing was stuck in one port. Gonna need a new MBC.
Lo-Fi Version Time is now: January 12th, 2025 - 12:11 AM
