Enthusiast Joined Feb 26, '11 From maryland Currently Offline Reputation: 0 (0%) ![]() |
I got a 95 celica Automatic and imctrying to install a automatic aftermarket shifter but i have no idea how to remove that stock 1 i unscrew it but it wont kome off idk if is because the overdrive button is on the side any help guys??
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) ![]() |
Yeah, its the wires for the overdrive that hold you back. I did mine a while ago and ripped out the wires by accident. No big deal, just wired it into an aftermarket switch. If you new shifter has an overdrive button you'll have to rewire it anyways.
Enthusiast Joined Mar 22, '11 From Auckland New Zealand Currently Offline Reputation: 0 (0%) ![]() |
I got a 95 celica Automatic and imctrying to install a automatic aftermarket shifter but i have no idea how to remove that stock 1 i unscrew it but it wont kome off idk if is because the overdrive button is on the side any help guys?? I have a 98 st and I swapped mine for a 7 gen stick type shifter but was a pain to do because of the wiring so just cut mine them re attached it looks great |
![]() Enthusiast ![]() ![]() Joined Jan 16, '09 From Cyprus Currently Offline Reputation: 10 (100%) ![]() |
I got a 95 celica Automatic and imctrying to install a automatic aftermarket shifter but i have no idea how to remove that stock 1 i unscrew it but it wont kome off idk if is because the overdrive button is on the side any help guys?? I have a 98 st and I swapped mine for a 7 gen stick type shifter but was a pain to do because of the wiring so just cut mine them re attached it looks great can you show a picture of it? cheers -------------------- ![]() |
I will add picture in the next day or so
This post has been edited by sweeny: Jun 28, 2011 - 3:14 PM |
I got a 95 celica Automatic and imctrying to install a automatic aftermarket shifter but i have no idea how to remove that stock 1 i unscrew it but it wont kome off idk if is because the overdrive button is on the side any help guys?? I have a 98 st and I swapped mine for a 7 gen stick type shifter but was a pain to do because of the wiring so just cut mine them re attached it looks great can you show a picture of it? cheers |
Lo-Fi Version | Time is now: February 17th, 2025 - 2:01 AM |
