> vacuum pipe
post Jul 17, 2011 - 2:52 PM
Gt4Driver
Joined Nov 2, '06
From Finland
Hi! Can somebody help me?
where do i put this pipe?
a pic would be nice
Replies (1 - 9)
post Jul 17, 2011 - 5:15 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Where is it coming from?
(\__/)
post Jul 17, 2011 - 5:52 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
If thats the vac line from the FPR then theres a port for it to the left of the TB
Why did you replace all your hoses? what's that Tee for that you put into your charcoal canister line
Mike W
269awhp / 273ft-lbs
post Jul 17, 2011 - 11:07 PM
Gt4Driver
Joined Nov 2, '06
From Finland
Its coming from throttle body. red circle.
Replaced all hoses because im looking a vacuum leak.
the tee is for my turbo pressure gauge, did i put it in a wrong place??
post Jul 19, 2011 - 1:03 PM
Gt4Driver
Joined Nov 2, '06
From Finland
somebody? help me out
post Jul 19, 2011 - 1:21 PM
3WayStunna
Joined Jun 25, '06
Goes to the charcoal canister
This post has been edited by 3WayStunna: Jul 19, 2011 - 1:22 PM
(\__/)
post Jul 19, 2011 - 1:41 PM
Gt4Driver
Joined Nov 2, '06
From Finland
ok thanks smile.gif so i can just leave it hanging around
post Jul 19, 2011 - 1:55 PM
3WayStunna
Joined Jun 25, '06
EDIT: do you plan on getting rid of your charcoal canister? If YES, then cap it off and ditch the charcoal canister...But you will probably deal with the smell of gas or maybe fuel vapors in and around the engine bay....
And you would also need to cap off that port on the throttlebody....
If not you would probably want to cap off both ends ( TB side/CC side) although i personally dont know how that would affect your engine...i would just route it through as it naturally would, as it isnt really a big deal.
This post has been edited by 3WayStunna: Jul 19, 2011 - 1:58 PM
(\__/)
post Jul 19, 2011 - 2:12 PM
Gt4Driver
Joined Nov 2, '06
From Finland
Well. it just fell off when i was doing something under the bonnet and did not find a place where to put it back.
where is this cc located?
post Jul 19, 2011 - 7:13 PM
3WayStunna
Joined Jun 25, '06
The charcoal canister is located as follows. Looking at the engine from the front of the car, it would be on the right hand side of the engine bay. Would be near where the fuel filter is located. If its not connected up right now, might explain your boost leak/vacuum issues.
(\__/)
Lo-Fi Version Time is now: January 11th, 2025 - 10:44 AM
