![]() Enthusiast ![]() ![]() ![]() Joined Oct 22, '02 From Toronto Currently Offline Reputation: 0 (0%) ![]() |
Hey guys, the car's been sitting for 2 years and I have 3/4 of a tank of gas in there!
I've been prepping the car to run again. I was wondering, how do I drain the gas in the tank so I can fill it with fresh stuff before I start her up again? I can't seem to find anything on a drain plug. I have a pump but whenever I try to get the hose down into the tank it won't go all the way (as if there's a anti-siphoning device somewhere along the way). Thanks a lot in advance! ![]() -------------------- ![]() |
just run it, my All-Trac sat for 3 years and it fired right up. the only way to drain the tank is stick a hose in the gas fill hole and suck it out.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) ![]() |
the gas going bad thing isnt much of an issue with the fact the tank is air tight. if it really concerns you u can disconnect the return line and hook up another hose to it and route that hose to whatevr u drain into, bridge fp & b+ in the diag box, and use the ignition key to start n stop flow.
Hey guys, my tank isn't air tight as there is a small crack in the filler sleeve. I can't find out how to drain the damn tank unless I get into the fuel pump - which I really don't want to do.. Looks like I'll go with adding Seafoam and preying when I start her back up again
Lo-Fi Version | Time is now: February 21st, 2025 - 2:21 PM |
