> boosting a 7afe. bolt in upper oil pan for oil return?
post Aug 1, 2011 - 2:45 PM
Por2geezcelica
Joined Aug 17, '08
From NY
Hey guys, im in the process of boosting my 7afe, and was looking at the oil pan today and noticed on the upper oil pan there is a bolt that is plugging a hole. I was wondering i can safely use this for my oil feed return fitting? If this can be used, does anyone know the thread size?
Replies (1 - 8)
post Aug 1, 2011 - 3:39 PM
do you have a picture of this? i dont remember seeing this bolt
This post has been edited by Smaay: Aug 1, 2011 - 3:40 PM
post Aug 1, 2011 - 3:46 PM
Por2geezcelica
Joined Aug 17, '08
From NY
the only picture i can find is from this ebay listing. Its located in the upper pan right in the middle:
http://cgi.ebay.com/ebaymotors/93-97-TOYOT...95#ht_500wt_749
post Aug 1, 2011 - 4:01 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
if its big enough id say go for it. i bet its an overfill drain plug of some sort, or maybe that piece crosses to a factory turbo part that has the return there (4efte maybe..?)
This post has been edited by stephen_lee: Aug 1, 2011 - 4:02 PM
post Aug 1, 2011 - 5:28 PM
Hafkai
Joined Dec 9, '05
From Germany
This screw is for the stock oil cooler return line on the EU models, iirc the thread is M12x1,25.
post Aug 1, 2011 - 6:03 PM
Por2geezcelica
Joined Aug 17, '08
From NY
thanks for the thread size!
Will this be large enough for a return line? What is the best return line size, and feed line size for the 7afe?
post Aug 4, 2011 - 7:48 AM
Por2geezcelica
Joined Aug 17, '08
From NY
What size oil lines should I be using? I'm thinking a -3 an for the feed with a restrictor and -8an for the return?
This post has been edited by Por2geezcelica: Aug 4, 2011 - 7:49 AM
post Aug 4, 2011 - 10:24 AM
yes definatly use a restrictor and -3 for the 7A-FE it has really high oil pressure and will blow turbo seals
post Aug 4, 2011 - 10:25 AM
Por2geezcelica
Joined Aug 17, '08
From NY
How about the retun line? -8an?
Lo-Fi Version Time is now: January 10th, 2025 - 12:48 AM
