> Headlight won't come on, I've pinpointed the problem, but I still need a bit of help
post Oct 1, 2011 - 2:21 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Short story: My driver side headlight won't come on.
Detailed story: I had 8000K HIDs, and the driver side was starting to lose a bit of color. I bought a set of 6000K HIDs to replace them a few weeks ago and finally got around to it today. I got 'em all buttoned up, it's perfect, everything's connected. Real cherry. So I start up the car and only the passenger side comes on. Several more switching on/off, same story. I'll also add that the driver side usually came on before, but sometimes it wouldn't and would take me a few tries to get it going.
My question is: Could it be the fuse? I'm heading up to Wal-Mart in a bit to get some, it's worth a shot. Does anyone have any other suggestions?
Edit: Both the old 8000Ks and the new 6000Ks are the same brand. Both Xentec, so it's quality stuff. The only difference is the 6000Ks have slim ballasts. The bulbs were protected with foam wraps and never dropped, dinged, tapped. The ballasts were cared for. So I'm highly doubtful it's the HID system.
This post has been edited by HectortheRican: Oct 1, 2011 - 8:42 PM
June '12 COTM
'95 AT200
Replies (1 - 13)
post Oct 1, 2011 - 2:57 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
connect your stock bulb on the stock elec lines first, if it lights up then its your HID system
post Oct 1, 2011 - 3:45 PM
HectortheRican
Joined Dec 26, '09
QUOTE (808celica @ Oct 1, 2011 - 1:57 PM) *
I'm so glad you said that. I have an extra 9006 in my trunk. Hopefully it's still good...
June '12 COTM
'95 AT200
post Oct 1, 2011 - 4:44 PM
richee3
Joined Jun 29, '08
From Denver
For what it's worth, Xentec is not quality. Did you get a whole new kit it just new bulbs? It could be an issue in the ballast but it sounds like you replaced the ballasts as well. It could be the fuse but those are kind of a worky/no worky thing, they don't just fade out like that. Nonetheless, they're easy to check so you might as well check the fuse. It's safer to run power wires directly from your battery to your ballasts so it's possible that a wire got cooked.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Oct 1, 2011 - 5:14 PM
HectortheRican
Joined Dec 26, '09
QUOTE (richee3 @ Oct 1, 2011 - 3:44 PM) *
Well I tested both fuses and they're good. I tested the wires with an extra 9006 bulb I had and that worked. So it's either the HID bulb or the ballast. What a bother...
Edit: Well I sucked it up and bought another HID kit. Xentec too... but it has a 2 year warranty. The first ones I had were Xentec and they worked just fine. These new ones, it's probably just a bad ballast.
This post has been edited by HectortheRican: Oct 1, 2011 - 5:26 PM
June '12 COTM
'95 AT200
post Oct 1, 2011 - 5:30 PM
richee3
Joined Jun 29, '08
From Denver
Try swapping your ballasts from side to side to see if anything changes.
1998 Celica GT-
BEAMS Swapped.
post Oct 1, 2011 - 6:07 PM
HectortheRican
Joined Dec 26, '09
QUOTE (richee3 @ Oct 1, 2011 - 4:30 PM) *
Eh, didn't think about that. Pointless now, I already ordered the new kit. I'm gonna go test if it's the bulb by using one of my old ones...
June '12 COTM
'95 AT200
post Oct 1, 2011 - 8:44 PM
HectortheRican
Joined Dec 26, '09
Alright, turns out that it wasn't the bulb OR the ballast (I'm not 100% sure on if they work perfectly, but I'll cross that bridge once I solve the actual problem).
So the REAL problem is the connector for the lights coming from the car's power supply. There are two wires connected to it, a black one and a white one. Well the black one is loose. That was the problem. Any ideas on how I can re-attach it?
June '12 COTM
'95 AT200
post Oct 1, 2011 - 9:06 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
wait which connector has the loose wire? you didnt specify on FB if it was your stock harness or the HID system.
post Oct 2, 2011 - 3:18 AM
chacha
Joined Dec 29, '05
From So-Cal
should have bought ddm kit... i recommend bc of lifetime warranty.
post Oct 2, 2011 - 3:34 AM
HectortheRican
Joined Dec 26, '09
QUOTE (808celica @ Oct 1, 2011 - 8:06 PM) *
Stock harness. I'm gonna try and jam it back in tomorrow. If not, I'll be making junkyard calls on Monday. Hopefully if I find a Celi, it has foglight stuff...
June '12 COTM
'95 AT200
post Oct 2, 2011 - 7:11 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
Mine used to do that. Ended up being the ballast going bad.
post Oct 2, 2011 - 9:00 AM
richee3
Joined Jun 29, '08
From Denver
Wait, it's a fog light? I thought it was a headlight. Any car with an H3 bulb will work, it doesn't need to be Celica specific.
1998 Celica GT-
BEAMS Swapped.
post Oct 2, 2011 - 12:53 PM
HectortheRican
Joined Dec 26, '09
QUOTE (richee3 @ Oct 2, 2011 - 8:00 AM) *
No, no it's the head light that needs fixing. I'm just hoping there's also fog light stuff so I can get mine wired.
June '12 COTM
'95 AT200
Lo-Fi Version Time is now: January 15th, 2025 - 1:36 PM
