> Cooling unit: heater doesn't work., Blower works perfectly.
post Oct 1, 2011 - 7:02 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
Everything works fine and the blowers blows perfectly but only cold air. The switch's motor doesn't work but I can switch it manually. The 2 prestone hoses get hot but the air in the car stays cold. (It's a Gt-Four model)
What could it be?
This post has been edited by dudeofchaos: Oct 5, 2011 - 4:50 PM
Replies (1 - 4)
post Oct 2, 2011 - 8:09 PM
either your heater core is clogged, or the shut of valve not working. check under the hood, there is a little valve that moves when you switch to heat..
post Oct 5, 2011 - 4:51 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (njccmd2002 @ Oct 2, 2011 - 9:09 PM) *
I looked and the shut off valve didn't move by itself so I moved it manually. The prestone hoses got hot but the temperature didn't rise.
This post has been edited by dudeofchaos: Oct 5, 2011 - 4:52 PM
post Oct 8, 2011 - 11:00 PM
clogged heater core, has it worked before?
post Oct 10, 2011 - 11:35 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (njccmd2002 @ Oct 9, 2011 - 12:00 AM) *
But that's what I'm expecting it to be since the air got just a bit warmer when I turned the switch manually.
Lo-Fi Version Time is now: January 10th, 2025 - 4:08 AM
