![]() Enthusiast ![]() ![]() ![]() Joined May 4, '05 From western MD/NOVA Currently Offline Reputation: 2 (100%) ![]() |
hey all, much as the title states, I'm looking for your cut-up, clipped, engine and or body harness. specifically for a 94-95 celica w/ the 7afe and auto trans, but I'm sure most any will suit my needs.
I know that there are allot of project celi's out there that have been swapped and in lou of speed had one or both of the for-mentioned harnesses cut up for quick removal, just to get it out of the way. offering $50+shipping: If you can provide a body and engine harness (or $25+shipping for one or the other) for an OBDI 7afe w/ auto (94-95) (specifically looking at the ECU clips w/ at least 10" for length off the clips) and most all of the other clips and sensor mounts to have at least a 10" tail off of em. obviously it would be nice to have it as intact as possible, but I'm not picky. I'm only looking for some clips "incase sh!t" and lengths of color coded OEM wiring so that i can do my tuck/extensions properly. USPS flat rate boxes do not cost much and have a nice high ceiling on max weight. so just cram it in there and don't worry about it. hit me up, and if i could ask for some pix b4 we go to the final step that would be great!! thank you in advance!! This post has been edited by mandrek: Oct 9, 2011 - 4:16 AM -------------------- |
bump
Enthusiast ![]() ![]() Joined Aug 29, '07 From San Diego Currently Offline Reputation: 0 (0%) ![]() |
hey all, much as the title states, I'm looking for your cut-up, clipped, engine and or body harness. specifically for a 94-95 celica w/ the 7afe and auto trans, but I'm sure most any will suit my needs. I know that there are allot of project celi's out there that have been swapped and in lou of speed had one or both of the for-mentioned harnesses cut up for quick removal, just to get it out of the way. offering $50+shipping: If you can provide a body and engine harness (or $25+shipping for one or the other) for an OBDI 7afe w/ auto (94-95) (on the body harness I am specifically looking at the ECU clips w/ at least 10" for length off the clips) and most all of the other clips and sensor mounts to have at least a 10" tail off of em. obviously it would be nice to have it as intact as possible, but I'm not picky. I'm only looking for some clips "incase sh!t" and lengths of color coded OEM wiring so that i can do my tuck/extensions properly. USPS flat rate boxes do not cost much and have a nice high ceiling on max weight. so just cram it in there and don't worry about it. hit me up, and if i could ask for some pix b4 we go to the final step that would be great!! thank you in advance!! I have a complete 5SFE uncut wire harness from a 1999 GT auto, is that what you're looking for???? |
hey all, much as the title states, I'm looking for your cut-up, clipped, engine and or body harness. specifically for a 94-95 celica w/ the 7afe and auto trans, but I'm sure most any will suit my needs. I know that there are allot of project celi's out there that have been swapped and in lou of speed had one or both of the for-mentioned harnesses cut up for quick removal, just to get it out of the way. offering $50+shipping: If you can provide a body and engine harness (or $25+shipping for one or the other) for an OBDI 7afe w/ auto (94-95) (on the body harness I am specifically looking at the ECU clips w/ at least 10" for length off the clips) and most all of the other clips and sensor mounts to have at least a 10" tail off of em. obviously it would be nice to have it as intact as possible, but I'm not picky. I'm only looking for some clips "incase sh!t" and lengths of color coded OEM wiring so that i can do my tuck/extensions properly. USPS flat rate boxes do not cost much and have a nice high ceiling on max weight. so just cram it in there and don't worry about it. hit me up, and if i could ask for some pix b4 we go to the final step that would be great!! thank you in advance!! I have a complete 5SFE uncut wire harness from a 1999 GT auto, is that what you're looking for???? that will work for my raw wiring needs, sure, but i honestly dont need it to be a un-cut, infact it would be best if it was not... im assuming you are refering to the engine harness, or do you you mean the whole thing(engine and body)? either way if you are ok with letting it go for the price points that im offering, let me know. And thank you for your responce.. -------------------- |
hey all, much as the title states, I'm looking for your cut-up, clipped, engine and or body harness. specifically for a 94-95 celica w/ the 7afe and auto trans, but I'm sure most any will suit my needs. I know that there are allot of project celi's out there that have been swapped and in lou of speed had one or both of the for-mentioned harnesses cut up for quick removal, just to get it out of the way. offering $50+shipping: If you can provide a body and engine harness (or $25+shipping for one or the other) for an OBDI 7afe w/ auto (94-95) (on the body harness I am specifically looking at the ECU clips w/ at least 10" for length off the clips) and most all of the other clips and sensor mounts to have at least a 10" tail off of em. obviously it would be nice to have it as intact as possible, but I'm not picky. I'm only looking for some clips "incase sh!t" and lengths of color coded OEM wiring so that i can do my tuck/extensions properly. USPS flat rate boxes do not cost much and have a nice high ceiling on max weight. so just cram it in there and don't worry about it. hit me up, and if i could ask for some pix b4 we go to the final step that would be great!! thank you in advance!! I have a complete 5SFE uncut wire harness from a 1999 GT auto, is that what you're looking for???? that will work for my raw wiring needs, sure, but i honestly dont need it to be a un-cut, infact it would be best if it was not... im assuming you are refering to the engine harness, or do you you mean the whole thing(engine and body)? either way if you are ok with letting it go for the price points that im offering, let me know. And thank you for your responce.. sorry for the late reply. Yeah just the engine harness I'm pretty sure its uncut. I'll post some pics in a bit. |
Lo-Fi Version | Time is now: September 13th, 2025 - 12:02 AM |
