> question about 7afe
post Oct 8, 2011 - 8:18 PM
matts94celica
Joined Apr 20, '11
From College Station, Tx
The oil pan on my old motor has an extension piece(the 2piece oil pan) my new 7afe has a smaller oil pan. Also on mine the top oil pan has a bracket for the transmission to bolt up to the block. My new one doesn't haven't the pan with the bracket so if I use the new engine ill have 4 bolts holding tranny to the engine. Well I'm debating on either doing that or taking motor back and getting money back and rebuilding my engine. I need help on what I should do...
Thanks, Matt
Replies (1 - 2)
post Oct 8, 2011 - 11:39 PM
you could use the upper and lower oil pan from your original engine. chances are you got a 7A out of another car instead of a celica. this happens alot in the 7th gen world. celica 1ZZ and 2ZZ have a bearing carrier for the passenger axle. corolla, matrix, vibe, etc, do not have this bearing. so the holes need to be drilled and tapped.
post Oct 9, 2011 - 2:00 AM
matts94celica
Joined Apr 20, '11
Thanks Smaay. But bad thing about that is if i change the oil pan out it'll probably void warranty from junk yard and if i do all this work and the engines no good then I'm looking at two engines that aren't worth ****. So, I'm going return motor and get money back and rebuild my original 7afe. Plus it'll be fresh for turbo.
Lo-Fi Version Time is now: February 18th, 2025 - 1:50 PM
