idea for a low buck coilovers, wanna see if anyone else thinks this could work |
Oct 9, 2011 - 3:35 PM |
Enthusiast Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) |
ok this is my idea I haven't hitting the parts to try it yet but it make sence in my head
could I use a set of front struts from a civic since there basically just a cartage an the cut the bottom half off the factory celica strut to make the sleeve for the cartage it sounds like a good low buck setup to me since honda parts are cheap an they have the right perch for coilovers any thoughts comment would be great -------------------- 95 gt coupe, v6 swap weekend toy
99 gt hatch beams swapped wife's 94 st hatch my daily driver http://www.6gc.net/forums/index.php?showtopic=82235 n |
Oct 10, 2011 - 2:26 AM |
I've been looking into this setup on superstrut suspension only because no company makes good racing coilovers for superstrut equipped vehicles.
Honestly it would take trial and to get a setup like this using different parts from different companys. I've looked and looked but no company makes struts a little bit shorter than our stock suspension. They are either too long or too short. Our Mcpherson geometry hinders us from making our own coilovers. Just buy Megan coilovers for $950 and be done with it. Trust me I've looked and looked all over the place calling just about every suspension company here in the USA and its gotten me no where. There is a company over in malaysia that does custom coilovers but they will run you over $1,500 easily and are meant for racing setups... -------------------- Group buy to replicate Narrow E series transaxle parts
Oct 10, 2011 - 9:56 AM |
ok well like I said it was an idea
I might still grab a couple junk shocks an try it out an see Wat happens -------------------- 95 gt coupe, v6 swap weekend toy
Oct 10, 2011 - 10:07 AM |
go for it man! it doesn't hurt to try something different
This post has been edited by mkernz22: Oct 10, 2011 - 10:07 AM |
Oct 10, 2011 - 11:28 AM |
Enthusiast Joined Nov 29, '09 From Milwaukee Currently Offline Reputation: 0 (50%) |
BC coilovers man... Best coilovers in that price range ... Definately worth the 995... Comparable to higher end coilovers
-------------------- Weekend Warrior-----1998 Celica GT: White Daily Driver----------1997 Celica GT: Blurple |
Oct 10, 2011 - 11:52 AM |
ok does anyone see a reason why this couldn't work
if it does I could have as little as maybe 300 bucks I know they wont predominantly as good as the high end stuff but it should get the job done -------------------- 95 gt coupe, v6 swap weekend toy
Oct 10, 2011 - 1:08 PM |
you can try all you'd like but the main thing if finding a shock thats the same height as the trd coilover inserts in which they don't exist. atleast not here in america.
megan coilovers/same as bc coilovers besides the spring rates allow for full adjust-ability and the best price range without having to go through the headeache of finding parts for your custom setup. -------------------- Group buy to replicate Narrow E series transaxle parts
Oct 10, 2011 - 1:19 PM |
ill try to gather the parts to make atleast one to see if it can be done this weekend
Oct 10, 2011 - 7:04 PM |
Enthusiast Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
do some reading about Suspension Geometry, dont just put parts together that will bolt up, you need to make sure you keep the stock geometry or the car will handle like total cr@p
as long as you make it the right length / angles, is a good idea, you can weld a piece of threaded pipe to make up for a shorter shock and bring it to the right length, and use the threaded pipe to adjust the coilover spinning the whole assembly to keep the rebound -------------------- |
Oct 10, 2011 - 7:19 PM |
thanks for the tips an the threaded pipe idea is a good one
im planning on using the celica top cap an the bottom of the strut for mounting them in hopes that ill br able to stay at the same stock specs as the stock strut -------------------- 95 gt coupe, v6 swap weekend toy
Oct 13, 2011 - 7:31 PM |
seems like a lot of hassle rather than just paying the one that fits your car.
Oct 13, 2011 - 9:18 PM |
seems like a lot of hassle rather than just paying the one that fits your car. your probably right but that part of the fun if working on cars is to try to do somethimg new if it doesn't work oh well at least I tryed an I learn alil more about how my car works -------------------- 95 gt coupe, v6 swap weekend toy
Lo-Fi Version | Time is now: November 30th, 2024 - 6:50 PM |
