![]() Enthusiast ![]() ![]() Joined Feb 3, '04 From West Windsor, NJ Currently Offline Reputation: 3 (100%) ![]() |
(almost) EVERYTHING MUST GO
It's a red GT Coupe with almost 194k miles on it. No sunroof, 6-speaker system for those interested in headliner and door panels. Everything that I can take off myself and isn't too big ships from New Jersey via [your choice]. If it's big/heavy (e.g. the entire interior) or I can't remove it fairly easy (e.g. rear motor mount), I'd rather you pull it yourself. Make an offer for whatever you want. For parts that come in 2s (or 4s, or whatever), I'd rather sell them as a set. Recently changed (within the past year): Front, Rear, Tranny Mounts (Anchor brand, last month) Sleeved the pipe that runs from the flex pipe to the cat. There was a flange there, now there's a sleeve because the stress that the bad mounts caused broke the flange (last month) Air Intake - Replaced with K&N and black metal short ram. Practically new (less than 5,000 miles on those) Timing Belt, Water Pump (new, not rebuilt), Thermostat, Water Pump Gasket (this spring, less than 15k miles ago) Spark Plugs (NGK Iridium), Spark Plug Wires (NGK OE), Distributor Rotor, Distributor Cap Belts (Power Steering, Alternator, and whatever the third one is) Valve Cover Gasket, Tube Seals Struts (KYB), Strut Mounts, boots, and bump stops Left Axle/CV/whatever it's called Also changed, but a little over a year ago: Flex Pipe Things you don't want because they're in crap condition: Left axle The power steering system as a whole - if you want certain parts, I'll inspect them and tell you the condition, but something somewhere is leaking so you definitely don't want the whole system Trunk lift struts Left low-beam Cabin air filter Certain parts of the interior - ask for specifics and I'll send you pics of them Head unit (aftermarket, CD player has problems) Gauges (Reverse Glow, but with LED issues) Driver's side window regulator/motor Front right bottom speaker from 6-speaker system Non-Standard Parts: TRD Shift Knob K&N filter and short ram intake (see "recently changed") Wheels are 17" Scion tC rims (not the new ones). Pretty bad curb rash on the rims of all 4; BARE RIMS, I had to move the tires to the new car Tanabe Lowering Springs. 2.2" in the front, 1.5" in the back. Not sure if the clutch is OEM. I just know it was changed before I got it (around 80-90k?). SOLD (or promised to people): Air bags + controller Alternator Climate control unit (the box with the knobs and the two cables) Valve cover + nuts Window trim Anything else, make an offer! This post has been edited by Rider: Jan 15, 2012 - 6:20 AM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) ![]() |
Window Trim (Both driver/passenger front and rear)
Enthusiast ![]() Joined Mar 26, '11 From MD Currently Offline Reputation: 10 (100%) ![]() |
What color is the car? I'm looking to buy the hood from you.
Enthusiast ![]() ![]() ![]() Joined Dec 11, '07 From Davie, Florida Currently Offline Reputation: 4 (100%) ![]() |
Any pics of the door panels?
Enthusiast ![]() Joined Jul 26, '08 From Fort Bragg, NC Currently Offline Reputation: 2 (100%) ![]() |
i need three female plugs with about 6 inches of wire still hooked to them. The far left one is the oil pressure switch female plug the other one on far right I have no clue what its called but you can see where it is in the photo. If you can get these two plus the one in the middle of them, they all come out of the same wire loom, for me that would be great. ![]() -------------------- ![]() |
NOTE TO EVERYONE: I'll be posting daily updates, but the car is about 15 miles away so I can only check items every few days.
Window Trim (Both driver/passenger front and rear) ? I have to check the condition, but I think all window trim is still good. $10+shipping? What color is the car? I'm looking to buy the hood from you. Red. Maaco paint job from a couple years ago though, so it's already dull. I think it's in good condition, but I gotta go and check. I'll post up pics Friday. Assuming it's not bent or anything, $75+shipping? Any pics of the door panels? I'll have pics up for door panels as well Friday, with details of any issues I find. i need three female plugs with about 6 inches of wire still hooked to them. The far left one is the oil pressure switch female plug the other one on far right I have no clue what its called but you can see where it is in the photo. If you can get these two plus the one in the middle of them, they all come out of the same wire loom, for me that would be great. ![]() I think I have the first two in good condition, but the wire broke at the top of the third? Again, gotta go and check. Pics will be up Friday. TL;DR? I'M RESPONDING TO SPECIFIC POSTS. PICS WILL BE UP FRIDAY FOR EVERYTHING THAT WAS REQUESTED |
Enthusiast ![]() Joined Aug 8, '11 From new windsor, new york Currently Offline Reputation: 2 (100%) ![]() |
are the front seats in good condition i live in new york so i will come pick them up how much
![]() Enthusiast ![]() ![]() ![]() Joined May 15, '09 From yonkers, NY Currently Offline Reputation: 8 (100%) ![]() |
how much for CC unit and MAP light?
-------------------- *Thing i want for my car(i wish i had money)*
-light blue tint (next step will do this right after i get my paint job) WTB Reasonably priced Projectors just Lows |
are the front seats in good condition i live in new york so i will come pick them up how much Driver's seat is pretty good, but the plastic part (where the seat back adjustment is) is loose. Passenger's seat has a tear right in the middle, probably 8 inches long and pretty deep. Are you willing to take them out yourself? Who knows, maybe you'll find something else you like* ![]() *Just kidding, I just don't want to have to take them out myself. QUICK NOTE: Several people have already asked me about shocks/struts and springs, so there's a sort of waiting list for each already. If you've PMed me, wait for a reply; otherwise, assume they're already sold unless I post otherwise. This post has been edited by Rider: Oct 20, 2011 - 11:22 PM |
Enthusiast Joined Sep 25, '11 From Sparta, Mi Currently Offline Reputation: 0 (0%) ![]() |
Do you have the center console ashtray?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
stock muffler?
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
$10 shipping, as long as its in good condition let me know what total is to 76106
Do you have the center console ashtray? Yes. It smells like smoke. stock muffler? Yup. Make an offer. $10 shipping, as long as its in good condition let me know what total is to 76106 PMed. What color is the car? I'm looking to buy the hood from you. Red. Maaco paint job from a couple years ago though, so it's already dull. I think it's in good condition, but I gotta go and check. I'll post up pics Friday. Assuming it's not bent or anything, $75+shipping? No pic necessary. No dents. PM me if you're still interested. are the front seats in good condition i live in new york so i will come pick them up how much Driver's seat is pretty good, but the plastic part (where the seat back adjustment is) is loose. Passenger's seat has a tear right in the middle, probably 8 inches long and pretty deep. They're worse than I thought. I'll PM you pics tomorrow evening. To str8thugginit4ya and foxcraze: Sorry, no pics today. I'll PM you guys pics tomorrow (Saturday) evening. This post has been edited by Rider: Oct 22, 2011 - 3:26 AM |
Enthusiast Joined Jul 17, '11 From Spain Currently Offline Reputation: 0 (0%) ![]() |
pm!
![]() Enthusiast ![]() Joined Sep 1, '10 Currently Offline Reputation: 0 (0%) ![]() |
got pics of the front seats???
![]() Enthusiast ![]() ![]() Joined Apr 18, '11 From Southern Alabama Currently Offline Reputation: 1 (100%) ![]() |
do you have the gt rear disc brake assembly? and how much? i only need the hubs and e break cable
dont need the rotors/disc or calipers |
Enthusiast Joined Feb 8, '09 From Moscow, ID Currently Offline Reputation: 0 (0%) ![]() |
How much for the driver's side tail light shipped to 83843? Thanks!
Enthusiast Joined Oct 22, '11 From NY Currently Offline Reputation: 0 (0%) ![]() |
I need the center bezel..(the one around the head unit/ac unit). I'm also interested in the engine mounts....I need the front/rear/driver side if available.
Thanks |
^ ^ ^ I'll have specific replies for you guys (LimitedGT4, rkelly_83543, jiggy2dmax) tomorrow afternoon/evening, sorry... I've been busy looking for another car pretty much 24 hours a day. Basically, everything you guys want is available, but the E-brake cable may be screwed up. The front seat pics for advancetoyota and kingcarlito4991 will be up tomorrow as well.
![]() Enthusiast ![]() ![]() ![]() Joined Mar 28, '04 From St.Louis Currently Offline Reputation: 15 (100%) ![]() |
Any chance you still have the two knobs from the heater controls?
I'll buy both from you if so. Thanks -------------------- ![]() 1994 GT Hatchback 1994 ST Coupe 1988 Corolla Wagon All-Trac 1999 Corvette 2008 Cobalt SS Turbo |
Lo-Fi Version | Time is now: February 19th, 2025 - 9:56 PM |
