Enthusiast ![]() ![]() ![]() ![]() Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) ![]() |
I have a question guys im in the process of building my 3sgte and I am going to go double filter on it with an aftermarket oil cooler system... my question is...
Where can I have the intake and out of the oil put...My mechanic suggested the oil turbo return line but i am not sure because if there is pressure maybe it will fill it up and have oil go up the wrong way on the turbo? any help is appreciated thanks guys... -------------------- |
![]() Enthusiast ![]() ![]() ![]() Joined May 13, '06 From Kaimuki, HI Currently Offline Reputation: 10 (100%) ![]() |
I have a question guys im in the process of building my 3sgte and I am going to go double filter on it with an aftermarket oil cooler system... my question is... Where can I have the intake and out of the oil put...My mechanic suggested the oil turbo return line but i am not sure because if there is pressure maybe it will fill it up and have oil go up the wrong way on the turbo? any help is appreciated thanks guys... I've been planning on doing the same thing except not with the double filter setup, only one filter. I have a oil filter bypass in place of my regular filter right now, I just have to get the lines, filter mount, and cooler. -------------------- -Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other 01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished 02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve |
I could go through the oil filter bypass but I prefer have 2 oil filter plus the bling factor lol I already have an HKS sandwich plate anyways for my sensors
![]() Enthusiast ![]() ![]() Joined Apr 20, '11 From College Station, Tx Currently Offline Reputation: 2 (100%) ![]() |
Well for the double filter kit I believe jegs sells a oil filter relocation kit with 2 filters. And for the cooler you can get the sandwich plate that has the 2 an fittings on it for the oil cooler
I already have the kit and its lines i want to know WHERE should i plug the IN and the OUT
On the oil cooler or the oil filter relocation?
I would prefer to have an electric oil pump with it's own reservoir to give the turbo it's own oil and cool it through the radiator or by other means. Then give the engine its own oil cooler and filter. That way I don't have to worry about the engine not outputting the right amount of oil to the turbo. Plus the electric pump would help me set up the car for the dry sump setup that I would like to run if I could ever find a kit.
On the oil cooler or the oil filter relocation? he's asking where on the engine would be the best place to route the oil cooling lines from/to. This post has been edited by match220: Oct 26, 2011 - 12:58 AM -------------------- -Jay
![]() Enthusiast ![]() ![]() Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) ![]() |
Hi,
murphys rule -> Whatever can go wrong, will go wrong i doens't understand the idea of putting a second oil filter in the system or a electric pump just for the turbo, nothing of that gives you a advantage you engine is just able to run a lont time well when it isn't complex with just the parts you are really need you just need: - greedy thermostatic adapter for the oil filter (the advatage against otehrs is that it also takes sensors) - a few lines - a radiator http://www.shopgreddy.com/accessories/engi...-4-x-16unf.html do not tough the turbo oil return line, there must be a free flow back to the oil pan, a turbo damage can occure greetz This post has been edited by Sunny: Oct 26, 2011 - 5:54 AM -------------------- |
So I can weld a bung onto the oil pan for my oil cooler return? where could I tap for oil IN that would have enough pressure/flow to go through the filter then cooler and back down into the pan
Enthusiast ![]() ![]() Joined Dec 30, '10 From amarillo texas Currently Offline Reputation: 6 (100%) ![]() |
well since only one other person has really said anything on this thread that was intelligent ill say it. this is retarded, your going about it completely wrong. there is not need to drill and tap or cut and weld anything. toyota put this nifty little thing on the 3rd gen in the oil pan where the oil filter goes. it gets oil pressure right from the oil pump. get something like the picture put fittings in it and it screws on where the filter goes, and it doesnt add any length or weight like a sandwich plate. hook up your lines with 1 filter, 2 filter, 10 filters whatever and you cooler and your done. there isnt anything wrong with running 2 filters its only going to clean your oil more and add more oil to the system so a plus and a plus, but stop trying to do stuff some completely off the wall way. the stuff to do it the right way are already out there and you dont have to take the chance of damaging anything in the process.
![]() This post has been edited by ST205WRC: Oct 26, 2011 - 12:58 PM |
Hi,
have a look http://www.6gc.net/forums/index.php?showto...t=0&start=0 here you can see a TRD filter mounted to a thermostatic adapter, the two lines go to the radiator the only one issue i have is that the current adapter do not uses sensor fittings, thats why i have a sensond adapter mounted the problem is that the filter becomes very down to the underpanel which is a little bit dangerous, i will go for the greedy one next year to get more safety, to safe space and for less complexity and parts that can go wrong (seals) greetz -------------------- |
the problem with the one with the adapter in oil filter pos. is that I already have a sandwich plate with sensor holes, What about the stock Oil cooler that goes on the block could I override that?
you do that then you have a bunch of water lines you have to do something with. trust me man the easiest thing is just going to be the adapter. they are cheap and easy just get one with sensor ports and remove the sandwich plate.
.....Mmmmmm Meh...I cant order anything i live too faarr
Hi,
the OEM cooler is fine, don't touch'em thats why i wrote you should use the greedy type adapter it houses a thermostat and can also take sensors use the link and have a look to the pictures http://www.shopgreddy.com/accessories/engi...-4-x-16unf.html greetz -------------------- |
we are gonna plug here...
and over ride the water cooling of the oil and go FMRad with an adapter like you posted... -------------------- |
Hi,
i would not, even it is a small radiator it helps to get faster normal oil temp. and helps to cool greetz -------------------- |
I get why you might not want to, But I don't want my oil to HEAT my water either I want to decrease the load put on my cooling system
the rad will is 19 rows...and it is over an inch thick ![]() This post has been edited by Neon90424: Oct 28, 2011 - 11:29 AM -------------------- |
you know what SUNNY just leave him alone. he asks questions and people give him answers and he doesnt want to listen. he does this every time he asks a question on here, he just argues with everyone that is trying to help him. so just leave him to himself, and we can just sit back and laugh when he blows it up AGAIN!!!
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) ![]() |
I get why you might not want to, But I don't want my oil to HEAT my water either I want to decrease the load put on my cooling system the rad will is 19 rows...and it is over an inch thick ![]() For you my good friend, dont get lost thinking that bigger is always better. When it comes to your oil you never want it to become too cool by getting a super large radiator core for your setup. I mean really, 19 rows?!?!?! That a tad bit extreme. When it comes to oil cooling most ppl would suggest 7-12 row cores for most engine builds. And if higher some would suggest adding in a thermostat of some sort so that the oil is only being cooled when it really needs to be cooled. -------------------- (\__/)
Lo-Fi Version | Time is now: February 13th, 2025 - 8:38 AM |
